HI!
And what about this one? MAMBA TOYOTA 1HD-T Landcruiser turbocharger w/ 1HD-FTE CT15B Core & Turbine Hsg | eBay
How would it compare with the TD05-18G?
Cheers
HI!
Cheers
Yeah basically a HDFTE turbo.
It's turbine is not super old school, but is definitely old school.
Pic 8 shows HDT CT26 turbine on the left with very square blade shape, newer style HDFTE CT20b CT15B curved blade shape on the right.
Looks like a super old school paddle wheel to me.
I was going to make a thread about this the other day. Some people claim the FTE turbo has a modern turbine but the pictures of them I've seen apart and replacement turbines I've seen for sale show a paddle wheel. Anyone got pics of their curved FTE turbines?
Only curved one that I have seen was a replacement for the ceramic ct20, but it has a larger journal and shaft OD than the ct26 small. It is also a 9 blade low back pressure turbine wheel.I believe all the FTE's got paddle wheels. Reason was to keep turbine drive pressures high enough to drive EGR flow.
I have seen a nicely curved CT20B turbine wheel from another application. It was not FTE and I didn't have accurate diameters.
I changed out the Nine blade wheel that came in my td05-18g for a 12blade unit. The nine blade does not build any drive pressure until tge revs are up. It reduces drive pressure at all revs and I believe it is for the tuner crowd. Spool was significantly improved with the 12 blade wheel. Feels way more responsive.Only curved one that I have seen was a replacement for the ceramic ct20, but it has a larger journal and shaft OD than the ct26 small. It is also a 9 blade low back pressure turbine wheel.
Turbo Turbine Shaft Wheel For TOYOTA 2JZ-GTE Soarer Twin CT20 9 blade Inconel | eBay
MAMBA TOYOTA 2JZ-GTE Twin CT20 Inconel 713 turbo turbine wheel (1 pcs). TOYOTA Soarer 2JZ-GTE JDM Twin CT20 turbo (17201-46010 / 17201-46020). Inconel 713. Replace ceramic turbine wheel directly. NOT for 1JZ-GTE twin CT12A or USDM 2JZ-GTE CT12B turbo.www.ebay.com
How much did your EMP increase after you swapped the turbine over?I changed out the Nine blade wheel that came in my td05-18g for a 12blade unit. The nine blade does not build any drive pressure until tge revs are up. It reduces drive pressure at all revs and I believe it is for the tuner crowd. Spool was significantly improved with the 12 blade wheel. Feels way more responsive.
Interesting read from the guys at Eclipse Turbos. Reinforces that fact I don't care to much about boost pressure. I'm much more interested in monitoring EMP and getting the lowest EMP:IMP possible which goes hand in hand with optimal gate setup.
It's all bollocks though. Bollocks intended to sell turbos with oversize turbines that don't produce enough boost.
Turbo surge on pedal release has nothing to do with turbine drive pressure. It doesn't float exhaust valves either.
Tune with an AFR gauge. If you drop boost to gain performance you will likely melt or crack pistons.
I now have one of these turbos and making boost has never been an issue.
ummm.... I've personally tested this and can assure you it definitely was the cause of my constant surge on pedal release.
Exactly why you should tune by EGT instead of only focusing on AFR.
It's actually pretty easy if you know how to setup the gate to change EMP while still keeping the boost pressure exactly the same.
You most certainly can! I guess I have the magic touchIt's pretty simple really once you realise how it all works.
