TFL 100 Series on the trail
I found this comment interesting:
"Inadvertently, you created a video showing the 100 series weakness. The ATRAC system is slow in this LC, unlike new 4Runners. When the LC began going backwards with the left wheel in the air, Tommy added power and spun that wheel. When the full weight of the LC hit the rock while spinning, broken differential was the result. ATRAC hadn’t kicked in yet. Lesson: if you’re going to rock crawl a 100 series, be aware of the risk, or put lockers front and rear. There are multiple videos online of similar incidents."
So my LC100 is Euro spec 2001 without ATRAC and with rear locker. Would I have had the same problem in this same situation too?
IMO, in that exact scenario, your rear locked 100 with locker engaged probably would not have rolled back nor have suffered damage.
But without the rear locker engaged it would have?
I'm just mostly curious, trying to stay educated and avoid similar situations. There's no rock crawling where I live, all we have is mud, snow and some sand.
@RockDriver Difficult to say but unlocked (F&R) and no ATRAC, if you two foot it (one foot on gas and one foot on brake) and ease into it, it would also not roll back like that. But you would also not make it up that without changing your line.
I watched the first vid a few days ago and chuckled at this one. These guys have good editing.
Very entertaining indeed. Lessons were learned from this video.
They seem to love taking their 100% bone stock 4x4's with passenger car tires off-roading. A set of a/t's wouldn't make for as good entertainment I guess.
They also seem to never air down.
  • Like
Reactions: GTV
It looked like throttle was being applied when it rolled back (front driver's tire appeared to be spinning). Almost like it was an ATRAC hiccup from it being in a diagonal spin condition. I've personally never had ATRAC do that on similar obstacles - usually it just stops making forward progress and makes a racket as the ABS pump clamps down on things until it eventually moves forward - but don't recall it ever rolling backwards.
@Rednexus It appears the driver tapped on the brakes with his left foot which defeats ATRAC and hence the rollback... combined with throttle and "boom."
There was some movement in the wheels, but totally possible it was a light "tap" as opposed to actually stopping momentum (which is what I normally do).
Regardless I'm glad I sprung for lockers and got rid of the even weaker 8" diff on my rig. Prior to diff upgrades, there were several obstacles I did not attempt due to a fear of blowing up my R&P.
Brake lights are on and wheels are spinning...
You are right, brakes were on, although the PS rear tires was still spinning forward. So he had one foot on the accelerator, foot on the brake (but not hard enough to stop the rig from actually moving), then a "pop" when it finally catches. Definitely interesting driving technique :).
Left foot braking is great for technical terrain but doesn't jive with ATRAC. If he was in a 98-99 without ATRAC, he should've had the brake on the entire time but modulated speed by releasing the brake and holding throttle.
So, the moral is: no 2 foot driving with an ATRAC 100? Just dont wanna do this to my truck.
