The last time you went for a brake tag / inspection sticker, did they open the hood or test the exhaust? If not, you're good to gut. I know the last time I went, the guy was so enamored with my rig, he didn't check a single thing.
Hey guys, just bought an 87 FJ60 and the smog pump seized up on the way home. Is that required to be working for La emissions or can I gut it?
kevin
depends yes like the adult diapers which parish ya B N![]()
I am speaking from memory here, but I believe your inspection stickr has a box for emissions stickers and mentions applicable parishes.
It is a new coil. Put it on in Tennessee.
Hey guys, I'm about to order some Amsteel Blue winch line and I'm torn between sizes, 5/16" (13,700lbs) and 3/8" (17,600lbs). My winch is an 8k Warn. What are your experiences?
Also I'm having a brain fart... If I'm using a snatch block and pulling an 8k load, am I actually exerting 16k of force on the line or 4k? I think it's 4 k since I would be pulling against myself, but I want to be sure.
QUOTE]
X2 I'd go with the 3/8 I wasn't impressed with the 5/16 I've seen used by others. I'm still using cable but will go to the 3/8 syn eventually. I liked the the Viking with [FONT=Verdana, Arial, Helvetica, sans-serif]Safety Thimble[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Viking Winchlines - Safety Thimble[/FONT]
if I am understanding you ?
the line still has 8k the block if stationary has 16k
you only get help on the line load by using multipliable sheaves like a block&tackle![]()
IMHO put the largest winch line on or by a factor of 1.5 - 2x of vehicle weight
that being said we probably never come close to max line pull unless you will b lifting the entire vehicle off the ground but they do bust drive line so no help plus get hung up on rocks stumps etc etc etc & I would rather a winch component fail than a line or block![]()
Yes you understood me correctly. So if the block has 16k and the rope has 8K since it's doubled over, then you should be pulling your truck with 16k of force, right?
