Tech Questions Here
loookin good John
is ther a reason why you have em under the cross member instead of above?
That is the only pictures I have of the fuel lines and it was during the crossmember install. Now they are back on the frame rail, not tie wrapped to the speedo cable.
John. Thanks. I don't think mine are factory... ;(
Thanks Cody Sent from my iPhone using IH8MUD
good 2 hear your not having the speedo cable over taxed:D
I'm thinking about bringing a pop up camper on my next trip to Hotsprings. I allready know that backing up is out of the question but is it legal in Louisiana / Arkansas to have a pull truck (LWB) , double axle trailer (20'), small pop up camper all at one time going down the hwy? I carry enough fuel that I can make it there with out gas station stops (for fuel at least) still need bathroom breaks
That'll be nice :) I know there is no law against it in Louisiana but may have to check with Bossman or Arkansas resident about their end. I see people all the time with a fifth wheel and boat on the back or fifth wheel and golf cart on a trailer behind it. The catch is not having to backup :D
yup sure can max length 43 in LA & yes in Ar length 65
Is that 43' and 65' is the length that can be pulled or is that including the pull vehicle length? (sorry I'm not a truck driver) I just drive a truck :D
Must be the total allowed length behind the tow vehicle I know just the LWB Megacab and my Fifth is 55FT and I have small one compared to some I've seen 36 and 40 Footers
Isn't there also something the only the last trailer can be bumper pull, any previous has to be a 5th. It's like I wanna say I read that somewhere.
Having to replace the driverside rear window on the hardtop of the 4Runner . Looking for recommendations on the best type of sealer to use when installing the 'new' window. Like everone I would like to do this once without having any water leaks. TIA
I bought a tube of that black 3M windshield sealant to seal the leak in my windshield but found out the hard way you want to wear gloves I had chemical burns trying to get that stuff off my skin.
is it gasket or bonded?
thought they were bonded
Does not look like a gasket . I will have to use a razor blade knife to remove the black "seal' that is holding the glass to the fiberglass hard top
then it a urethane can buy a tube at any glass/ windshield supply or go by let em install shouldn`t cost much.
can talk to my windshield guy if U like.
