Probably a dumb question, but is it locked?
Have you looked above the license plate to see if there is a latch there?
Well, I found the problem, I couldn't find it last night, there is a "lock lever", which isn't powered. The key hole just does the back window, I got it now. ;$
Thanks Cody Sent from my iPhone using IH8MUD
Applying direct heat to the TRE threads, then dousing with water would cause the threads to experience a more drastic temperature change which in theory would cause a more drastic size change.Why heat then cool? I have always heard you want to do your work while it is hot before it cools and shrinks back up.
Two hammer's ... hit at the same time on opposite sides pitman...hit hard may take several hits!!!
Do any of y'all 80 guys have this problem
https://forum.ih8mud.com/80-series-tech/765909-weight-capacity-gutter-mount.html
