Tailgate Armor
Whatever happened to the 80 with the propane stove installed in the tailgate...
Other ideas:
Padded suede for the sensitive rear end.
Shag carpet for the pimp 80.
Finished mahogany hardwood plank pink panty wagons.
You forgot the cottony soft terry cloth for those wearing pink panties. :princess::idea::flipoff2:
Dan, I like the look of your flat aluminium... If you have or had ammo in those cans I want to fly out and visit you.
Oh, the nomenclature on the cans is accurate.:)
I think us 80 guys are missing an opportunity here- check out kevinrowland's work :cool:
https://forum.ih8mud.com/showthread.php?t=102938
As Dan once said to me,"You spend too much time on your knees", or is that what I said to him???:confused:
I used diamond plate because I got it really cheap. I throw a packing blanket on it for cushion and all is well.
Don't go with the 1/8", go with the 1/4". I rounded my adges off with a Bastard grinder! Clogged it right up.
Nice storage idea Dan!;)
FAQ?
This is a great mod as I have seen many warped tailgates.
In fact I think the tailgate armor should be added to FAQ mods if it hasn't already. It would fit nicely under other modifications - unique and the not so common.
Seems like a fairly simple mod and most question have been answered except for what size nutserts should be used on 1/4 inch plate?
Also, if Cruiserdan or someone else with the mod could snap one more picture so the location of all the nutserts can be seen.
One last finishing touch would be to apply some of that roll on bed liner in a matching interior color. Keep in mind this would make sliding items in and out a little more difficult. But you wouldn't have to worry about your expensive ammo falling off.
I used 6mm nutserts inserted into the same holes that the factory clips go into. You have to open the holes up slightly with a drill.
I have another plate in my garage right now for my wife's truck. It's already cut but I still need to drill it and radius the lower corners. I plan to install it this weekend and I'll try to get some photos of the process.
That answers all my questions. Pics no longer required but would be a bonus.
Dan, I like seeing your Rubbermaid "drawers". They are the same as mine. I thought I was the only crazy one!
I put dividers in mine. Love them as they are light and easily replaceable. I can take them all the way out for access and they fit perfectly.
The panel above that holds mine down slides out. I screw legs into the bottom of it to make a table.
I just covered the stock carpet with carpet protector from Lows. Cost about 6 bucks and is still "easy on the knees". Keeps the carpet from absorbing water if left open in the rain, also easier to clean mud, grease from the stove or anything else off of.
Previous to my career as a zombie hunter for the government, I was a chef, that being said, has anyone thought about using a sheet of poly cutting board? its heat treated, doesnt hold bacteria and can be cleaned pretty easily. You can get sheets in different sizes and trim to fit with a jigsaw.
That would not provide the extra rigidity that the 6061 plate does. A main reason for this mod is to stiffen up the gate.
I think that may be incorrect, super high density polyethylene has a better rating for rigidity and only slightly lower for tensile strength. As far as the benefits of 6061 obviously it would be thinner. I only suggested the poly board as an alternative for those that do alot of cooking/prep on the tailgate.
HAHAHA, my Spanish grandmother and Italian aunt both have that same carpet protector! :p
And chance you have plastic covering your leather seats :flipoff2:
Agreed on the food prep angle. Mine is more of a work bench tho.
Well isnt there a silver compound you can treat on the metal to make it food safe? I have seen it used on hi-end homes to treat the stainless steel everything in the house to help with the germ-o-phobes. For the life of me I can't remember the name. Besides, even on poly it means you can't cut pork/chicken on it or else you have to treat with bleach.
