Tailgate Armor
Personally what I am thinking of is using aluminum sheet doubled up with a piano hinge up top along the top of the tailgate. Then riveting some collapsing legs from a really old card table. That way its out of the way, I can open the tailgate like normal BUT now I can pull the table open and drop the legs and now I have an actual table!!!
I am soooo doing this now.
when cutting poultry or swine/beef its generally a rule of sanitation to clean your cutting surface with a solution of consisting of 1 Tbsp bleach per gallon of water. I always clean my counters and cutting boards whenever i cook, even in the outdoors, there is a prep for steel counters but its never suggested to use that surface as a cutting board. It will destroy your blades. I always keep a small bottle of pre-mixed disenfectant in my camping gear. So if you have a flip down/over panel with legs, would the legs be removeable? or do you have to set up the table everytime you open the tailgate? Seems like that may make it hard to get stuff out of the back.
Hehe, no plans on cutting on metal, I was also a chef for many moons. :P
The idea is to cut on a poly board with silicone feet/back and use the table as a prep area.
The legs that I am thinking about using are off a card table. The kind that fold down and under the ip of the table. Every old person has one to play gin or whatever they play nowadays. But the idea is to make the legs collapsible on the table as well that tuck in against the tailgate
HAHAHA, my Spanish grandmother and Italian aunt both have that same carpet protector! :p
And chance you have plastic covering your leather seats :flipoff2:
Actually no, but I have seen that down here in the south, saw this subaru yesterday and all its seats were covered in hard plastic. That must be the sweatiest car to drive especially when its 100 degrees out.
I did it to the back carpet because I am always getting mud and sand all over it. I think the aluminum plating with linex would be best though.
