Syn P/S fluid
San Diego, CA
Alright, so I know that conventional oil and synthetic shouldn't be mixed but how about P/S fluid, does this rule apply here as well?:steer:
Ulyses
all synthetics are incompatible with all conventional fluids. They should not be mixed regardless of the lubricating, hydraulic system you are thinking of. Just do a p/s flush and you would be fine.
Although, a caveat to that would be engine oil. You CAN top off with using synthetic oil without any harm. But its a waste of synthetic. The properties that make synthetic a better choice are degraded by mixing with conventional engine oil.
cool thanks, I went to pepboys and by mistake a grabbed a bottle of synt p/s fluid, I was not going to mix it before asking :cheers: thanks again
Better check twice, you don't want power steering fluid in toyota power steering systems. Mine uses mercron/dextron atf. :hillbilly:
Toyota PS units use ATF not power steering fluid. And, I've mixed regular Chevron ATF and Mobil1 synthetic ATF for the last 100k with no failure yet. I think it's probably OK.
That's simply false....
You can buy engine oils, for example and that dino and synthetic mixes.
Granted it's a complete waste of synthetic, however it simple will not hurt to mix them in any application, engine oil, gear lube, ATF, whatever.
Fred
Guys it makes zero sense to just top off or add with synthetic. All the reasons for using synthetic are negated if you mix. If you want the full benefit of using a synthetic, use only a synthetic, don't mix. I never said you will destroy parts by mixing, they are just just incompatible in that the benefits are then gone. And there are some oils that CANNOT mix at all. You can't mix R12 refrigerant oil with R134a mineral oil. And you should never ever mix DOT 3 brake fluids with synthetic. I have witnessed the damage that can do.
Probably everyone here would interpret "incompatible" as meaning CANNOT mix at all. That is the correct definition of the word:
- Incapable of associating or blending or of being associated or blended because of disharmony, incongruity, or antagonism
- : not compatible: as a: incapable of association or harmonious coexistence <incompatible colors> b: unsuitable for use together because of undesirable chemical or physiological effects <incompatible drugs> c: not both true <incompatible propositions> d: incapable of blending into a stable homogeneous mixture
So that might have been what you meant, but it wasn't quite what you said ;)
Fred
As others have stated above synthetic ATF and conventional can be mixed without issue. In fact, this has been done by a number of mudders including myself that have done the drain and fill method of changing the Tranny Fluid.
I just bought some Mobil 1 synthetic ATF and it says right on the bottle that is "compatible with conventional ATF". I used it today to flush my power steering system following Raventai's instructions
Several here have been using Mobil DTE 24 (iso 32) I switched over about a year ago, been quite happy with it.
First let me say that your contributions to this forum and the FAQ are exceptional! Thanks for all the great information.
I looked at this link on the ExxonMobil website and was just curious, I'm a ChE and not a lubrication engineer but how did you figure out that this stuff would work as a substitute for ATF in a Toyota power steering system? The applications that they list are fairly general and I wouldn't be able to make that leap. Again, not questioning but just wondering.
I had tred other ATF fluids and found either pump noise (light cavitation when cold) or or with others darkening and a "burnt" smell so I followed the recommendation of other members here who had long term success with DTE 24 and so far have had neither ailment.
my understanding is that Toyota spec'd ATF as a convenience for the owner to reduce the need to stock another fluid.
ATF is basically hydraulic fluid with additives for a transmission, some for anti wear others are friction modifiers for the clutches,
the PS system is a basic hydraulic system and needs the anti wear additives for the pump and steering gear but not the friction modifiers,
The viscosity of DTE 24 is close but slightly thinner than DexIII and therefore should feed better but no so thin as to break film.
Code:
                   DTE 24      DexIII
cSt @ 40º C 	    31.5         35.3
cSt @ 100º C 	     5.2          7.4
Viscosity Index     98          183
Flash Point  ºC    220          180
Dextron III refrence:
Mobil ATF D/M
Thanks RavenTai! I've been doing quite a bit of research on fluids recently as I just bought an 80 in January and want to decide what to use, and how to use, between now and summer (when it will be driven quite a bit).
Btw, it's only 10:30 in the UK which makes it 5:30 AM in Georgia.....early riser? :D
late sleeper, I recently went to 3rd shift (graveyard), 3 days on 4 days off,
