suspension suggestions
Oklahoma City, Oklahoma
i know the topic is old and worn out but for a newcomer to the cruier world your opinions are invaluable..... this christmas im planning to lift my stock 75 fj40 and i was wondering if i could as some advice. i want to keep the leaves under the axels simply for financial reasons but i have aquired a set of 3" skyjacker leaves that i plan to rearch and put on in place of the factory ones and im considering 2" shackles or so as well. i hope to fit 34x9.5 when the project is over. my question is what all i actually need for this project as far as hardware goes and what this project is going to cost me. id also like to know what all it entails i assume im going to have to shim the axels and lenghten the driveshafts and break lines but i dont intend to do the driveshafts myself and was wonder what this will cost and where to get it done. any suggestions or opinions are appreciated. thanks guys!
First, a question. Does Skyjacker really sell 3" springs? I just put 4" springs on the rear of my '74, and I think they also sell 2" springs.
In my case I run 35X12.50 BFG MT tires. I have the rear 4" springs with the long shackle.
In the front I have a shackle reversal and Rancho springs and stock length shackles. The vehicle sits level. I haven't taken it out to see if I could rub the tires in the rear like I used to be able to before. Before I lowered the rear bumpstops 2", and swapped out Rancho 2" springs, I used to get some rubbing when I was really using the suspension , like when I had opposite corners up on rocks and the other tires drooping. I suspect I won't get much rubbing with the new setup.
Hope this helps.
im not quite sure what the springs are. i assumed that they were 3" springs as that was the difference i measured between them and the factory springs laying side by side. i sent the springs out to get rearched today, they had been used before i recieved them so i broke them down. while im on the topic how do you dimension springs in reference to rearching. do they go by overall lenght or what?
also, i was wondering if i put the new springs on what issues aside from brake lines am i going to have to deal with.......will 3-4in of lift need improvements to driveshaft length or angle
Aside from rear brake line, you may need to install shims between the axle and leaf spring to correct caster and pinon angle. (caster int he front, pinion angle in rear).
2.5" shims corrected my caster up front with skyjacker 4" lift.
I did not need any shims in the rear.
Entended shackles will also throw this off.
pzyche said:
Can somebody please suggest a suspension lift kit for an FJ40 with a 7" lift (SUA) and 44" tires? Thanks! Online store links would be appreciated :)
What kind of first post is this?
Not possible, would suck really bad! Maybe SOA and lif springs?
I have a friend that ordered like 5" springs from Alcan for a 40. I have NO idea what he was thinking. I think he just measured and decided 5"s would be good (not thinking that Alcan was going to do 5" over STOCK). Those springs are absolutely terrible looking, short and WAY over arched.
If you want that much lift, do a SOA.
pzyche said:
Thanks for the reply, guys. I am just helping out a friend and I sure will tell him to go for SOA. So, what's the best suspension lift kit can you suggest?
stock springs.
