Is that photo POST lift?
Careful adjusting toe - that'll chew up tires fast.I was taking a look at the tire rods a few days after my alignment because I wanted to adjust from no toe in to about 1/8" toe in to see if it helped with the truck pulling to the right. Are they supposed to be adjusted evenly right and left?
The passenger side looks to be threaded so that it is about 3/8" shorter than the drivers side (threaded in closer to the steering rack). I'm not sure if this matters but just wanted to check.
Sent from my iPad
Excessive toe settings often bring with them drivability problems, especially during heavy rain. This is because the daily pounding of tractor trailers on many highways leave ruts that fill with water. Since excessive toe means that each tire is pointed in a direction other than straight ahead, when the vehicle encounters a puddle that causes only one tire to lose some of its grip, the other tire's toe setting will push (excessive toe-in) or pull (excessive toe-out) the vehicle to the side. This may make the vehicle feel unsettled and very "nervous."
Additionally the vehicle's toe is one of the most critical alignment settings relative to tire wear. A toe setting that is just a little off its appropriate setting can make a huge difference in their wear. Consider that if the toe setting is just 1/16-inch off of its appropriate setting, each tire on that axle will scrub almost seven feet sideways every mile! Extend it out and you'll discover that rather than running parallel to each other, the front tires will scrub over 1/4-mile sideways during every 100 miles of driving! Incorrect toe will rob you of tire life.
Seem to have flex in the rack from worn bushings.I was thinking of steering rack buahings.
Was it really difficult to get the old bushings out and put the new ones in?I haven't looked at the GX rack assembly, but I did put poly bushings in my Tacoma around 268k. The OEM ones were shot.
Did you have to remove the steering rack to replace the bushings?Not terribly. I'm also used to working on MR2s, so anything that has room is a luxury to work with. [emoji14]
