So I dug into my suspension project today. Good fun.
I'm looking for advice on three things:
It seems like junk collects in the low spot and it just rusted this nut to the point where it isn't removable with a 14mm anymore.
The 14mm doesn't have any purchase and the 13mm won't fit over it. There's no room to hammer a socket over it, and it is too tight to get a Dremel in there. I'm dreading getting at it in this small space.
I also had lots of fun with removing the rear shocks. The lower bolts came out fine, but the upper nut was rusted solid. Solution: reciprocating saw, 9" metal blade, and patience.
Lots of room to work in:
- Tips for removing the outer tie rod from the spindle (BFH to the side of the casting didn't work). Special tool people prefer?
- How to get clearance to remove the passenger side rear spring (disconnect the pan hard bar??)
- Tips for removing a buggered nut on the front upper strut mount (of course it is the inside front one that is the hardest to access).
