Superchargers
It may be an irrelevant question at this juncture. Last I heard there was a lack of availability.
Toyota TRD had them until a couple months ago for about 3K give or take. Recent posts tell that they are discontinued. For high altitude they are reported to work great. About 60+ HP and Trq. (TRD says 100 but no one I heard believed that.) If you can find one new grab it. There may be some at Toyota dealerships somewhere. If not look at a re-gear about 2K.
I was saving for the SC but missed out. I live at 6200' and travel up to 9000 frequently. I am doing 4.88 gears eventually with 33" tires. The bigger the tire the lower ratio re-gear (higher number ie 5.33)
If you look at it from a technical point of view, a turbocharger is a better fit than a supercharger because the S/C is a positive displacement pump and needs to spin faster at higher altitude than at lower altitude in order to move the same mass of air. A turbocharger is is directly related to the exhaust gas volume and automatically adjusts for altitude.
Check out scottryana's thread on his build.
Supercharger*= $$$
Turbocharger** = $$$$
* SCs no longer made so moot point.
** No bolt on turbo solution so requires lots of cash/skill thrown at the issue
Any thoughts on installing a supercharger on a 1997 TLC? I live at a high altitude and have been told that it is a good idea. Manufacturer? Type? Good idea or not?
Was talking with Magnuson Products (Superchargers) today about superchargers for 200 series. Magnuson bought the SC rights from TRD. They will be offering the Tundra 5.7 initially but with land cruisers to follow.
He mentioned these engines 3.4, 5.7 4.5 and 4.7. He said the 4.5 inline 6 for fzj80 - not sure what years of LC yet, nor when would be available but that's their plan.
I'd call them and give them your info. They are collecting caller list to contact once things are ready.
Contact List for Magnuson
I spoke with sales.
Exciting.
Not to mention the dismal thermal efficiency of a positive displacement pump compared to a centrifugal compressor. I've always been amazed at how few superchargers are set up with aftercoolers, while almost every turbo is.
This thread interests me..... the turbo comment seems off, though
At higher altitude the air is thinner with less o2 in it... and is why some are saying to boost the motor, for increased o2 to the engine.... explain how a t/c wouldn't be impacted by the thinner air, again? Understood that the exhaust side is spun by exhaust gasses, but if thinner/less combustible air is entering the engine to begin with, the amount of air being pumped out (though the exhaust) is also bound to be lower....
I saw the other thread regarding lack of availability.... makes me wonder why everyone only wants "bolt on" affairs. Within that thread there was talk about cost/percentage to boost over cost of the vehicle itself.... my point of view on that (to an extent is just the opposite) but... wouldn't those who want boost/off road capabilities, who have mechanical/fab capabilities, who are buying these at lower initial costs tend to be the ones to figure out non-bolt on variants?
For instance - what's stopping anyone from going to a junkyard, finding a mercedes with an M90 that has an electromagnetic clutch, using square tubing to fab some brackets, then build some piping? I would guess those with the right fab skills could pull that off for just a few hundred bucks....
The MR2 crowd does this pretty often when they jump from an SC12 to an SC14 - although they're similar, they also require fabrication of just about everything to get to work.... the only difference is that from an electronics standpoint they're already boosted. (I did have an 87 MR2... paid $100 and put a lot more into it to s/c it).
I would also wonder how t/c lag would be impacted by thinner air as well, which the s/c wouldn't have (lag, that is).
As for the intercooler (interesting that someone said aftercooler... which would be more technically correct on a t/c, but not so sure on an s/c where the IC would be between the 2 pumps... the s/c and the engine) Toyota did install them on the MR2's and, at least in Japan, the corolla's that had 4agze's.
The air going into the engine is regulated by the amount of exhaust exiting the engine, this is correct, but under load, there will be an excess of air being supplied, this is controlled by the wastgate, which regulates the amount of exhaust that is allowed through the compressor, by bypassing it.
So yes, it does automatically correct for altitude.
A turbo at 0 ft or at 8,000 feet will still run the same boost.
A supercharger will loose boost with altitude...
Superchargers are driven at a finite ratio, while turbos are free to spool as fast as their system will allow. For this reason turbos get closer to sea level horsepower, while superchargers fall off at the rate same as n/a motors as elevation goes up. Pretty big factor when the highway 40 miles out of town passes 11k' and you're pulling a trailer.
Have both, live and play at altitude, and like both - but they behave differently.
I'm going to gloss over and ignore a whole bunch of stuff here and condense this down to something other than a book. If you have questions about anything I say, please quote the sections and ask away. That having been said, RTFM... go find Maximum Boost by Corky Bell and devour that book. While some of the technologies he cites as being cutting edge are now obsolete and almost comical, the physics, theories and math is as good now as it was when the book was written. And so without further adieu, think of it this way...
A positive displacement supercharger will not compress the charge air internally. Instead, it simply pushes it through the intake manifold and into the engine and makes boost by moving more air than the engine could naturally ingest. Because the intake valves are not all constantly open, this is how it creates the pressure in the intake manifold. Since the blower is mechanically linked to the crankshaft, there is a fixed relationship between blower RPM and engine RPM. The faster the engine spins, the more air it needs, and the faster the blower spins in conjunction with the engine, the more air it moves. If you look at dyno plots of engines before and after positive displacement superchargers have been installed, you'll notice that it looks like they basically just took the curves and raised them higher up the scale. The only way to change the boost pressure is to change blower RPM in relation to engine RPM, and the way that's done is by changing pulley size on either the crank or most likely, the blower. Since blower and engine RPM are fixed, a supercharged engine is susceptible to the same losses a naturally aspirated engine experiences in regards to meteorological conditions.
A turbocharger, on the other hand, is not restricted by engine RPM, but rather exhaust gas flow rate. To control and regulate a turbo, a wastegate is used to divert a metered amount of exhaust gas away from the turbine to avoid excess boost or shaft RPM. The wastegate uses a simple diaphragm and spring linear actuator that takes its vacuum and pressure signal from the intake manifold to open and close a valve that diverts the exhaust gas. If the wastegate is set to deliver 10 PSI to the intake manifold, then the turbo will supply that as long as there's enough exhaust gas volume to spin the turbine fast enough. If you go up in elevation or are operating when the density altitude is high, you will still see 10 PSI boost because the turbo will be spinning faster than it would at sea level because the wastegate isn't diverting as much exhaust gas. An added bonus of high elevation or a high DA is that there's less back pressure downstream of the turbo, which will reduce spool time.
As a side note to plant a seed and because nobody mentioned them... centrifugal superchargers (think Procharger, Paxton and Vortech) are the worst of both worlds- high parasitic losses of a belt driven blower and the lag of a grossly oversized turbo.
Nothing is stopping anyone other than it's going to cost a lot more than that. Not plumbing in an aftercooler, especially with the cooling issues already present with the 1FZ is stupid, short sighted and half- assed. Add $500 for that if you want to do it right. Then there's fuel management. You can chicken**** an extra injector in there somewhere or bump fuel rail pressure through the roof, but if you're gonna do it, might as well do it right and go with some tunable engine management and bigger injectors. Drop about a grand for that and then another $600 or so for dyno time to tune it. Then there's the back end of things what with the exhaust and all, so expect another $1500 for a complete exhaust system and header. Finally, there's the fabrication you mention. If I were to build a bracket for a blower, it'd cost me under $100 in materials. For you or anyone else, significantly more because my time and knowledge is worth money, and it's not going to be some square tube bull****, either. Designing and engineering a bracket to support something as massive as an M90 isn't as easy as slapping some tube together and calling it good.
Lastly, the M90 is too small for the 1FZ. I don't have a ton of time now to get into the how and the why, so you can either take my word for it or call bull**** and force me to do math tomorrow.
That was me, and aftercooler is the proper form of address for any heat exchanger between the turbo or SC and the throttle body. An intercooler is only used between staged compressors, such as in a twin charged setup between the turbo and supercharger, or in a staged turbo setup between the turbos. In either case, if an intercooler is used, you can still use an aftercooler between the final compressor and the throttle body.
A lot of this has already been done on this board multiple times. Sumotoy laid it out years ago, I redid the compressor maps to show everyone. No need to do the math, it's been done.
Your make shift ideas will not work on an OBDII truck, without doing an O2 sensor manipulator.
Either way, it's good the TRD system is coming back but it is kind of a half assed setup. It works but is not ideal. A charge air cooler would go a long way towards making it more dependable in my opinion. There have been 2-3 diy's that were pretty good but no suitable shop option. EMS offered to give one a way to use a truck as a template and no one took them up on it.
Anyways lots of horse beating going on in this thread, I would go checkout the other supercharger thread if you want to be kept apprised of the return.
For all the EMS exhaust issues that came along and probably helped lead to their demise (I had an EMS exhaust too), I sure do miss them because of all the turbo development/engine management work they did. They were the closest to having a complete turbo kit of good quality that I know of. I hope it's only a (short) matter of time before another good turnkey kit emerges.
Looks like I better get working on my 2JZ-GTE Swap.
How hard is it to find a Wrecked Twin Turbo MKIV Supra?
Funny enough there was a Toyota in top truck challenge this year with a turbo 2JZ in it. Lol
From my personal experience, I live in Fort Collins Colorado at 5000 feet, I have had a diesel transplant 80 series as well as an LX 450 stock, I now have a TRD supercharger in my 97, it is a significant difference from stock, even with 35's and a 4 inch lift. I feel that it brings it to more of a modern standard of what you would expect a new vehicle to feel like, does not push you back in your seat but it can actually accelerate up the hills and mountains in Colorado. I am looking at doing a regear to 4.88 which should have another positive affect on the truck
