supercharged videos?
So minus supercharger, turbo, and exhaust what are my other options for more power. btw i already have a magnaflow and although its not as loud as the flowmaster it puts out more power, but its not that noticable. thats why im looking for another power alternative, even though i do realize the 80 was not built to be a speed demon.:doh:
Gears? :confused:
Old Turbos have LAG, No longer an issue with todays turbo's, cost nothing to the motor, driven by exhaust gases. Although it must be set up correctly. Again it COST NOTHING, does not effect the engine or take power from it.
That's funny, most every time in Car and Driver they test new vehicles, even in the current issues, they still talk about lag. Granted, it's not as bad, but it's still present. The turbo still has to spool up, it's not continuously cranking away at a zillion rpm.
And it does affect the engine. Superchargers add about 7psi of pressure where a turbo adds 2-3x that.
A turbo provides free power compared to a SuperC that takes Crank power to make power. The exhaust is already OUT of the engine so use those hot gasses to spin a small fan to provide a compressed intake charge. For the TLC I like the SuperC mainly because of simplicity, will get one someday depending on future paychecks. About the TurboLag, that depends on LOTS of factors and deep pocket books but you can do away with the lag or design the system so the boost kicks in exactly where you want it. (deep pocket book) Again I don't prefer a turbo to the TLC over a simple intercooled SC setup but I do have other Turbo vehicles and a few more turbo engines...
In a simpler form and if you have connections, progressive Nitrous... Could also up the compression and gain a bit more power their as well but the power to cost ratio might not be a good one.
Sorry for the jab, I put one of these :D intending it to be a ribbing, joke, I guess it wasn’t very funny, again sorry.
Never heard it said that engine has to push harder to get the gases out?
NEVER
You may have never heard it explained that way,,, EVER!:D But that how it works on all 4 stroke motors. The exhaust valve opens and the piston pushes the gasses out, this process requires power. A less restrictive exhaust requires less power and a more restrictive exhaust takes a higher percentage of the power that the motor produced to get the job done. The whole equation is more complicated than that and bigger gains/losses are made due to tuning, pulse timing, scavenging, etc.
A turbo isn’t a free power deal, have you ever run a turbo motor with the intake/compressor side disconnected? If you dyno stock motor. Then install a turbo, only connecting the exhaust side, it will produce less power than stock and run like it’s choked, because it is, exhaust choked. When the intake side is hooked up it overcomes the efficiency losses and makes more power.
That said turbo almost always have a better power used to power gained ratio, a more efficient setup. But both systems use some power to make more power.
whats the best way to push out more power out of the 1fz engines? supercharger is just to much cash for me to put out right now.
I wouldn't say charging it. It just makes the engine run faster, and not at its peak torque rate. If you want more power, get new linkage equipment. T-cases and whatnot. I wouldn't modify the engine itself if you want to keep the zj.
Someone said muffler, that's not a bad either. But for a substantial increase, you gotta look to the linkage to get more torque. If the engine just runs faster, you'll lose power.
Ask what people do with their linkage's when they apply lift's. There's some power loss in there and they do something (not sure what) to regain the horse power they lost when they tilted the drive shafts.
But if you're looking for speed, charge that baby.
Huh? There's no change to the RPMs of the motor. There is a change to the amount of air compressed into the cylinder available for mixture and detonation.
The supercharger produces it's torque early, which is great off-road. All LC motors produce torque at low RPMs.
And I have no idea how you expect new "linkage equipment" to produce more power.
Huh?
Huh?
1Fz...9.0 cr...3.94 bore x 3.64 stroke
hp 212 @ 4,000 rpm
trq 275 @ 3,200 rpm
You call that low!
3fe...8.1 cr...3.70 bore x 3.74 stroke
hp 154 @ 4,000 rpm
trq 220 @ 3,000 rpm
I call that low(er)!
I reserve the right to remain silent UNTILL I see the Torque curves!!! :D:D:D
If Toyota made low rpm motors the gears wouldn't be so high, they just now figured it out....with the "americanised" 100, LandBlober, BlandCruiser and so on..
Huh?
hp 212 @ 4,000 rpm
trq 275 @ 3,200 rpm
You call that low!
hp 154 @ 4,000 rpm
trq 220 @ 3,000 rpm
compared to the 1GR-FE (this is measured by the new standard- direct comparo to 1FZ numbers, the HP would be @ 265HP/?tq)
Max HP @ RPM
245 @ 5200 RPM
Max Torque @ RPM
282 @ 3800 RPM
Huh?
hp 212 @ 4,000 rpm
trq 275 @ 3,200 rpm
You call that low!
hp 154 @ 4,000 rpm
trq 220 @ 3,000 rpm
The redline of the 1FZ is 5k RPM, the redline of the 3FE is 4k RPM. So, the 1FZ makes it's torque a little over halfway before redline. The 3FE makes it 800 RPM before redline.
You should just remain silent, no until.
Huh?
hp 212 @ 4,000 rpm
trq 275 @ 3,200 rpm
You call that low!
True, max torque is at 3,200, but the "curve" is relatively flat, IIRC it makes 90% of max at 1800 rpm, so yes I call that low!
3FE redline is 4600. Close. But it makes no difference. It's gutless past 3800. I speak from experience.
The 1FZ makes more torque at idle than the 3FE at it's max...IIRC... Maybe that was compared to the LR 4.0... There are HP/torque charts floating around here somewhere.
Agreed. xInfinity
Harold,
Other options...One that comes to mind is tweaking the ECU programming. I don't know if other companies do it but I know JET does. You remove your unit, ship it to them, they do their thing, and send it back. Your rig is down in the interim obviously. Cost is around $300 IIRC and JET "claims" 10-13HP gains. I'm not sure spending $300 to get (maybe) 10-13 more HP is worth it but that is an option.
Other things that come to mind would be better flowing air intake (snorkel - although there is some debate whether this really helps or not, free flowing filter but NOT a K&N, think oilless here, etc) and ummm...that's about all I can come up with.
Obviously if you lift the rig and put on bigger tires then changing the gears, while it won't give you more power, it will bring back some of the peppiness lost (if you can even mention 80 series and peppy in the same sentence :flipoff2:)
Personally, having done headers, free flowing intake, free flowing exhaust, and chit deal in a non-80 series vehicle before and seeing what LITTLE difference it really made (like a 5-10% gain in HP) I don't plan to waste any money on these items on my LX. Someday, maybe, my LX will get supercharged or turbocharged. To compliment one of those options I'll probably add a snorkel and better exhaust.
turbos all have some lag. Always have and always will. turbo tech in the automotive industry has not changed enough to matter. Vartiable vane tech was to be the godsend but its not-look at the 6.0 powerstroke that just went back to an oldfashioned twin turbo. ceramic bearings-big deal
No such thing as free power. Takes power to make it. heat and backpressure are huge power barrons on a turbo.
Peak torque isn't till 3200 rpms but the torque curve is pretty flat way before that.
$9000 installed for a proven system is a steal. I have $50000 of time and headachs in mine...wouldn't have it any other way
