supercharged videos?
Sacramento, CA
I was just wondering if there are any videos of an 80 LC with a supercharger installed . I want to see and hear the difference it makes.
Yes, they rob power, but the net gain is like an additional 60 or 70... I can't remember. I know the TRD SC takes the 1FZ from 212 to around 280.
Turbos rob power too. :flipoff2:
Sounds about the same. The vehicle is faster, but it is still an overweight brick trying to push air.
Isn't there a "whine" usually associated with a Roots-type SC? I watched a TRD Tundra go by today, it was clearly supercharged...had the whine and everything. Sounded nice.
Mine has a little bit of whine. Even my wife can hear it: "it sounds meaner".
Karl
Mine has a pronounced whine, originating from the front passenger seat, when a certain set of circumstances exists......
whats the best way to push out more power out of the 1fz engines? supercharger is just to much cash for me to put out right now.
A few guys here have turbo'd their 1FZ's.
turbocruiser is the only one I can think of right now... :doh:
Search it up, see what you can find. There are a number of turbocharger threads. :cheers:
EDIT: There is one turbo thread going on right now, "Turbo Build", OP is Dusty.
:lol:
No worries then since the supercharger appears to be made of "unobtanium" right now :frown:
I considered this after talking to Chris Wood at ARB and his thoughts after driving a supercharged 80 and a turbocharged 80 was that the turbocharged 80 felt "better" to him...
Unfortunately this isn't something I can handle doing myself and at $9K installed through Slee I can't justify spending nearly what I spent on my LX i the first place on a turbocharger :rolleyes:...Of course supercharging isn't cheap either but IIRC is is quite a bit cheaper that $9K installed.
Dont think so,
Super charger Vs. Turbo, USED TO BE Lag Vs. Power lost
A motor absorbs a lot more power with a supercharger (costs a lot to make a lot) due to how the impeller is driven (belt, crank driven) it is instantaneous, off the bottom. (Sorta like the A.C you might not "feel" it on but its robing power.)
Old Turbos have LAG, No longer an issue with todays turbo's, cost nothing to the motor, driven by exhaust gases. Although it must be set up correctly. Again it COST NOTHING, does not effect the engine or take power from it.
Let's get one thing straight I'm not saying EITHER are a bad choice. But like most other things all things must be taken into consideration.
Dont think so,
Here is an old saying that fits, it goes something like this; If you don't know WTF you talking about, it better to keep your trap shut than open it and proclaim your ignorance to the world!:D
What your telling us is, when you put the supercharger on your rig it reduced the power?:confused:
... Old Turbos have LAG, No longer an issue with todays turbo's, cost nothing to the motor, driven by exhaust gases. Although it must be set up correctly. Again it COST NOTHING, does not effect the engine or take power from it. ...
So your saying that no power is needed to pump the exhaust gases out, it just naturally flows out? Putting an exhaust restriction, in this case exhaust turbine in the flow has no impact on motor power?
So minus supercharger, turbo, and exhaust what are my other options for more power. btw i already have a magnaflow and although its not as loud as the flowmaster it puts out more power, but its not that noticable. thats why im looking for another power alternative, even though i do realize the 80 was not built to be a speed demon.:doh:
