- Thread starter
- #21
Thanks for the feedback. I may regret ordering this used one, but if it works, I saved 300 bucks and if it doesn't, I wasted $100.These sunroofs are delivered to Toyota as a unit, with the seal permanently installed. Unlike the 100s and 200s, which have $30 replacement seals, you have no option other than to buy the replacement glass. Yes, for $400, if you can find them for that.
You and I know what the problem is; someone with a later model can't appreciate what a PITA the glued on fabric is. The glass is the only sealed component you have to worry about. Everything else you can take care of when you swap the glass. The pan seal is another story; I don't see how that would be easy to get at. I think you can get the glass out of the early models without mangling the headliner fabric, but not the pan. Someone who's done it before would be a better resource than me. @cruiserdan probably knows.
I agree I'd stay away from used glass, even if it's "verified" leakfree, when it was removed. The seal's 20+ years old. Read my earlier posts on the sunroof drain subject; @MoJ, post #10, is correct, the dust seal on the glass does tend to regulate the ingress of water, but it doesn't seal it out at all. The drains were intended to carry the water away from the interior. If you've a rust problem, I doubt it's a clogged drain tube, although it's not impossible. More than likely it's a dirty rocker panel void. The pinch drains get plugged and the water backs up, into the floorboard and the sunroof tray/pan/frame (whatever we're calling that these days; Mr. T calls it the housing assy)
As for how this got rusty to begin with, I am at a loss to diagnose it because I haven't had any leaking symptoms in the 18 months I have had the truck. If I end up having to order a new unit, so be it, but I just had to buy a new fridge on Friday for my house and I am a little tapped out at the moment.
I am starting to see why so many people hate these sunroofs.
