Sudden Power Loss
The O2 sensors were on my "in the next phase" of baseline items but it looks like that may be stepped up. Going to see if the recall on the sensors was ever done, if not perhaps I can get a better deal on the sensor kit.
Installed the new coil a couple hours ago, as soon as the drive is clear going for a test drive and see what new surprise is in store. Will it be :clap: or :bang:
If it didn't throw any code or set the CEL, it sounds like a low level electrical fault upstream from the ECU like a bad / corroded fusible link. Whatever it is, it sounds like it cuts power to the ECU so it can't even think to throw a code.
I have not had that possibility presented yet. I have been meaning to build new cables and have the materials less the fusible links but I have not had the chance to determine what the lengths need to be. Been preoccupied with chasing my tail it seems. Have to see if anyone has done a write-up on building new cables.
Thanks for some thinking in a new direction.
Went by and saw Tom and Larry and had them bring in two of the fusible link sets for me and then strolled over and had service do a history check and see if the O2 sensor recall had been performed on this lovely. No surprise, it was done in '99. The paperwork that came with the 'Cruiser showed the original owner took it to the dealer regularly for everything.
So back to Tom and Larry and got the O2 sensor kit ordered.
O2 Kit for '93-'94 P/N 89465-60110 includes both sensors, gaskets and new nuts.
Fusible Link set P/N 90982-08264
With luck the power loss thing will be finally found in the fusible links and the O2 code will be resolved.
I am not doing cartwheels yet but installed the new fusible links and took the 'Cruiser for a 5 mile test drive and it did not act up.
Considering yesterday it would not even move out of the garage, that's progress.
But I have been fooled before so it needs more miles. Hope to get the new O2 sensors installed in the next week
On a "damn dude" note, if this issue has been caused by the fusible links then I won't feel as joyous about the $800.00 worth of other parts and days of work chasing down a $10.00 fault.
We shall see.
keep us posted...how's it doing?
I certainly will.
When searching the forums when this developed looking for possible causes there was nothing that gave me a clear path for trouble shooting what to look for. When I get this done-and-dusted I hope to have others in the future to have a more clear path to follow.
We went on an extended weekend up north and only returned home today. All I can offer is that with about 30 miles since the fusible link replacement it has not re-spawned the symptoms. Looks good but still not ready to say "Done and Dusted" on this. When I have 100+ miles and no re-occurrence then I will do a happy dance.
Hope to get the new O2 sensors installed this week if work will allow.
OK, got about 50 miles on it since the fusible links were replaced and not a single hint to the problem reoccurring.
Some times it takes a Pin_Head to point out the simple things.
Thanks for the lead down that path Pin_Head
Spoke to soon.
Drove it today and it fell on it's face again. I am at a loss.
I'm sorry to hear that due but yay, we get to troubleshoot some more!! I have a feeling that replacing the fusible link caused your ECU to reset and maybe that's why the problem took so long to resurface? I dunno, just a WAG.
Still, no CEL when this happens? If so, your ECU maybe be losing power somehow. Anytime the ECU loses power, the subsequent engine startup tends to produce a high idle. Are you experiencing this at all?
With the new O2 sensors installed it is a pig to start...starts...stumbles and stalls and once started it is running high idle and really really rich.
Every step in this seems to make things progressively worse than better. I am at a loss. It may be time to seek professional intervention.
Just got back from another long test drive and picking up a new part for the 'Cruiser...
On a more serious note...
After the complete cluster on starting this morning and the stalling and stumbling that followed on the short groceries run it actually ran pretty well for most of the 35 mile round trip in to Chandler and back. It idled at 600 rpm and ramped up to 800 when the AC compressor engaged and fell back again when it disengaged. On the freeway it accelerated well (as well as you can expect with these things) and cruised without a burp.
Got 4 blocks from home on the way back and accelerated from a stop at the intersection...it went flat, stumbled, went flat and then picked up again and went on.
I did get a fresh CEL on this trip, so the ECM is talking to the rest of the truck but on checking it is the CEL 71 again for the EGR.
I have the TPS I ordered yet to install, I don't think it is the issue now but I have it so on with the new and out with the old. Developing a big box of working spares :).
PinHead, I will be going back over all the wiring again and pulling the ECM out again and checking under the dash for anything. I did double check when I was pulling the new CEL code to make sure all the connections at the fusible links I just did were tight and solid.
Unplug the egr put jumper in it , loop the vacuum lines and see if that fixes it, this will essentially bypass the egr and not run it, 93 and 94 will run fine without it just make sure you put jumper wire in the female side of the harness
