Sudden Power Loss
@ajax1
Unplug the egr put jumper in it , loop the vacuum lines and see if that fixes it, this will essentially bypass the egr and not run it, 93 and 94 will run fine without it just make sure you put jumper wire in the female side of the harness
What vacuum lines get looped ?
OK, I'm going to call it.
200 miles and the 'Cruiser has never run better.
It looks like the TPS was the major culprit.
If your going to chase this type of drive-ability issue I would say: Replace the fusible links first, they are the cheapest and easiest common source for weird things effecting the ECM and related symptoms.
The Throttle Position Sensor, while not difficult to replace on its face, with the throttle body still in place on the vehicle it is a testy bugger to get set properly. A buddy and a set of feeler gauges with the 45 degree bend make it easier.
Now, on to the exhaust replacement and change to the '96 y-pipe and moving the O2 sensors.
Post Script
My thanks to one and all who offered potential solutions to this. This forum and its contributors are some of the best around. Thank you one and all.
Pickle man here, had the problem with accreting and cut in and out of power, I think i found the issues. The 4 wire plug and wires that connect to the throttle position sensor all fryed, so waiting for the new plug and pigtail so I can solder and marine heat shrink in. Already put in the factory new TPS.
I forgot to mention, gorilla duct taped temporary until connect comes in, runs much better while waiting for the part.
