Subwoofer wiring question
Hello. I am replacing my sub on my 2001 LC, and have a question on the wiring. The new sub has two connectors, while the wiring has 4 wires. Can someone help me an tell me what color wires I need to connect to the sub to make this work?
Thanks
Nobody is answering, and I think it's because there are too many variable to give a concrete answer. But I'm willing to throw out some issues with short explanations of why it's a problem.
Does your model have the dual 4" subs in the back? If yes, then I expect the amp is using two wires to one sub, two to the other. I'll come back to this later.
Does your model have only the 6" sub in the back (mine does), then if you open side panel and check the connector you would see that while 4 wires go out of the amp back to the sub, only two are actually connected to the woofer.
Both the above implies a single channel driving a single sub, each having two connectors.
Returning to the dual 4" sub case. It is possible that the amplifier could be used in bridged mode [one channel (-) wire combined with the other channel (+) wire], but it's also possible that trying to do that would fry the amp. I've never read an account of someone who successfully bridged the OEM amp (doesn't mean it can't be done, I just haven't read about it).
Complicating the issue is the Ohm rating of your subs. I know my 6" Nakamichi sub is a 6-Ohm woofer. I have read the later model ML models use a 12-Ohm woofer. Bridging an amp usually means the Ohm rating of the woofer(s) it drives has to rise. So if the dual 4" woofers are each 4-Ohm rated, an bridged amp might require an 8_Ohm woofer or risk death by overheating from current flow.
Long winded way of saying that before giving an answer, I think most would need to know your factory sub quantity/type, and the Ohm rating of the sub you want to use.
Thanks so much for your response. My truck is a 2001, and it has a single JBL 6 5 3/4 or 6" sub.
The head unit is a Kenwood, with an amp installed, but no sub woofer amp. If there are only two wires going to teh sub in my set up, it shopuld be relatively easy to connect another 6" sub?
I am thinking of adding a Pyle 6" which is rated at 4 ohms - do you think this will be OK?
Again, great response, and I thank you!!
2001 w/ single sub. I also had 4 cables. I just used the two that worked and cut the others. Dont know the difference but its been fine for me. Also, the bass sucks even with new sub. I just replaced cuz it was torn.
.... If there are only two wires going to teh sub in my set up, it shopuld be relatively easy to connect another 6" sub?
I am thinking of adding a Pyle 6" which is rated at 4 ohms - do you think this will be OK? ...
Yes, it will be easy, and yes 4-Ohms should be fine. You shouldn't expect to have thumping bass, impressing the cars at a stop light with a 6" sub, regardless of brand. That would apply even to the (relatively) mighty JL Audio 6" sub. For bass notes, it's like the US big block guys say, "There's no replacement for displacement", and the more air you displace the more bass you get. If everything else was equal a 12" sub would produce about 4 times the volume of a 6" sub (since the woofer cone area is proportional to the radius squared, so 9 vice 36).
If you want more quality than Pyle, but not a high end budget, you might cruise through the offerings at places like Parts Express and look for a woofer that has the most linear excursion (Xmax) that fits in your box and budget. This one might fit depending on your box shape/size.
If I had enough money (I don't) and wanted a sound quality woofer to fit in the OEM location using the factory box, I'd pick up this one from Madisound.
Thanks All..much appreciated. Yes, I understand that I wont get thumping bass, but thats OK. I liked the factory set up as it fit my needs. I am not a loud bass kind of guy, and am replacing it because the factory sub is torn.
So I guess the easy way is to figure out which two wires work, and hook those up?
...So I guess the easy way is to figure out which two wires work, and hook those up?
If you pull the side panel you should find a connector going into the woofer housing. If it's like mine you will find 4 wires going into the connector, but on the enclosure side there are only two pins (might have to take the enclosure out to see unless you use a mirror - my connector was pointing down IIRC). That will tell you which two wires carry signal out of the amp. Then if the woofer enclosure is anything like the one on my 2000 LX, inside the enclosure you will find two wires you could clip at the old woofer then re-solder then to the new or put on the appropriate connector to match up to the woofer you buy.
EDIT: I type too much and too slow. bucfl's method is probably much quicker.
Bringing up this old thread for some advice. I bought a Pyle PLPW6D 6" and wired it up. My '06 only had two wires, black and red so I hooked up only two of the four speakers inputs. Sounds OK, but as soon as I turn up the volume the stereo quits for about a second. Where did I screw up?
I think stock woofer is 12ohm so a dvc 8ohm would get you closer to 12ohm
Call crutchfield, they are always helpful and know their stuff. If your new parts are not compatible, they can get you the right stuff at a decent price.
Dont flame me on this but I dont have the mental capacity to go through the 22 page thread on this. Same as above, I have an 06 LC and upon removing the factory blown sub, I have 4 wires (two pairs, one green/black, one yellow/red). All 4 wires run all the way to sub and ive determined its red and black that are both negative, and yellow and green that are both positive. I got a single voice coil 8 ohm sub for a replacement so it only has two connection terminals. I can wire it up multiple ways and it does work, I'm just wondering if there is a correct way and non-correct way to wire. Thanks much!
I just replaced the sub on my 06. I did lots of reading on the various posts, and figured it out. I’m no expert, but this is what I ended up doing…
Mine has the JBL sound set up with the single 6” sub. The stock sub has 4 wires hooked up to it and operates at 8 ohms.
The trick is wiring up a dual voice coil 4 ohm sub in series to produce 8 ohms. Wiring it in parallel will produce 2 ohms, which we don’t want with the stock amp. I ended up going with a 6.5” Skar subwoofer, which is wayyy more beefy than the stock sub. There is a post that goes into much more detail, but this image really helped me understand the wiring. The Skar I got required much more plastic trimming and modifying of the original enclosure than I anticipated, but the outcome is pretty decent, maybe 10% better than stock sound. My sub was blown, so no regerts.
If I had to do it again I would have researched the depth and dimensions of the stock enclosure more and opted for something that fits it better. The stock amp doesn’t put out crazy power so a crazy overbuilt sub won’t blow your mind unless you are changing more than just the sub.
Hope that is helpful.
Hey vintagecruisertx thanks for the response! I read up on the skar option with wiring it in series but was turned off by exactly what you mentioned, too much box mods. Thats why i went with the 8 ohm single voice coil option. Looking for pointers about how to wire my 4 wires to a 2 terminal speaker. Heres the speaker i got. Cheap but fine! Visaton W170S-8 6.5" Woofer with Treated Paper Cone 8 Ohm - https://www.parts-express.com/Visaton-W170S-8-6.5-Woofer-with-Treated-Paper-Cone-8-Ohm-292-568?quantity=1
I changed mine a while back with a Kicker unit, here’s my post.
Single VC will just use one set of the wires: blue and blue/yellow OR blue/black and blue/red.
I went with with one of these. Alpine SS-SB10. I figured there was only so far you could go using the stock enclosure. The plastic panel will just rattle. But I needed a better amp to drive it. Admittedly not a cheap solution - but it sounds sooo nice. I can live with a little box in the back of the wagon. It's easy enough to remove if I need to.
