2002 LC - Kicker subwoofer replacement review - Pros and cons
Los Angeles
So I posted earlier that I’m going have to replace the original subwoofer due to squealing like a pig. Yet I’m not convinced that Kicker is the best solution even though Crutchfield suggests that it will fit my 02 LC. I searched “parting out” without luck but found a good used OEM on eBay for $200, I offered $150 but later sold. Brady Adventure posted a video using a $23 size 6.5” x 2.9” Pyle subwoofer modified by trimming it to fit. However, he commented that it’s just ok sound. With all that work, I like to see same or better than OEM sound quality. Being 8 years old video, any used JBL subwoofer would be 20 years old so I think Kicker should be better than both used OEM and Pyle. I ordered from Crutchfield, subwoofer arrived quickly with installation kit, discounted at $103 size 6.75”x 2.75”. Also I choose Kicker in case I need speakers, they are available for LC and rated 2025 best so future matching speakers.
I follow Brady’s instruction to removed the panel. The OE subwoofer crumble into pieces the minute it got disturbed. Upon removal, the Kicker fits nicely on top of the JBL subwoofer housing without modifications, however the outer ring protrude about 1/4” plus above the original JBL. I don’t feel comfortable to trim as the Pyle is smaller, Kicker fits so perfectly other than the outer ring height. I figured out the wires, nice spring loaded quick disconnect feature, installed the subwoofer using 1 1/2 screws then full blast for a test run. It sounds amazing at full bass with no distortion and definitely better than ever so very pleased! Now looking at the panel, I wonder if it would have enough space for the extended 1/4” so I installed the panel, it pushed the center spacer grill section out a bit may be 1/4”. I removed the panel and see where are the interferences and where to cut the inside grill to clear the outer ring. Then I noticed the panel is missing 3 white retainer clips, ordered the clips and put the panel back on, I put a dap of clear silicone on the clip next to the speaker so that it would hold but the clip above the speaker will require a modification to larger retainer clip or cut the inner grill. Upon final installation since the clip won’t arrive for a week, it looks okay although the gap is there but it’s not noticeable. The interference does not affect the sound quality, after I put back the third seats and sear belts, not noticeable but also not perfect. So here’s my rating on Kicker subwoofer. Overall, 9/10 I’m pleased Kicker subwoofer while she compliments the original JBL speakers.
Pro- excellence sound quality better than OEM using original JBL housing.
Reasonable price, easy installation if you don’t mind a gap on top of the speaker grill area.
Con- not a direct fit while modification required cutting into side panel grill.
Kicker subwoofer installation procedure:
1. Remove tailgate scuff plate screws 5 each.
2. Remove both seat belt bolts 14m
3. Remove side panel small plastic cover T20
4. Remove rear 12v connections and front connector to subwoofer
5. Remove driver side plastic door sill protector
6. Remove rear side panel, start from the rear once all clips are loose excessive forces required
7. Option 1, cut wires remove JBL subwoofer and connect wires green is hot, black is ground, yellow is hot, red is ground then install Kicker subwoofer.
8. Option 2, leave assembly as is and cut 4 wires remove damage subwoofer using T20.
9. Center Kicker subwoofer in situ with JBL housing ensure sitting flush and install self tapping screws while holding.
10. Test sound system, if satisfactory install panel in reverse orders.
11. Check panel fit, if unsatisfactory remove panel and cut interference contacts. Repeat…
Missing several retainers on my panel, looks like 10 locations. The one above the speaker grill will not be strong enough to hold so either needs to cut the panel inside grill or special longer retainer. I put some silicone on the one rearward of the center speaker ( last pic ) so that it would be strong enough to hold without popping out.
Here are a few pictures of the panel gap. I’m the picky OCD OEM type, but overall a satisfying project for an old truck. Noticed not many topic on subwoofer but a lot of request when I was searching parting out section so I hope this is helpful. I enjoyed this LC as easy to work on for an old dude, lol. All the best!
Good to know, thanks!
Are you on original speakers or using Kicker speakers as well?
I replaced the original speakers with Morels everywhere else.
GRV those are nice speakers, may I ask if you upgrade the original stereo as well if so to which model and your take on it ? Thanks!
Mine is non nav so the head unit is unique for North America. It’s basically cheap generic T’eyes and it’s not great.
