Subwoofer, factory location/hidden
I’d be interested in the file or better yet, a spare bracket if anyone has one. Just curious if this bracket only fits this CV subwoofer or could be adapted to other similarly sized boxes. Also, i think this was mentioned before but all wiring/power would need to be re-run and not really feed off existing sub wiring?
I built it to fit my Rockford Fosgate PS8 so it obviously fits that one. Other people mounted Cerwin Vega and I think a Kicker as well?
You're correct, you can't reasonably use the factory sub wiring.
I can email the file to you. I'll just need an address. 😉
Sent PM
@I Lean I received your DXF file a while back (thanks!) and have since forwarded it to someone for fab but they need actual measurements. I cant view what’s in the file but i assume it’s just the bend pic you shared earlier in this thread. Any chance you have those separately or can add to an image, or if you are still in the business of making these upon request? I feel this is going to be more complicated than it’s worth to get someone to mock this up as good as yours, especially without access to my vehicle. Thanks,
Could someone send me the file as well or if someone has an extra ready I would buy it. Thanks ohmstyles@gmail.com
Well, I neglected to get pictures and I'm not pulling interior pieces for them now, but I just finished with my install.
I don't have convenient, affordable access to any sort of CNC cutting implement, so I printed the template and cut it out with a thin disk. I DO have a brake, so it was easy from there. I simplified the design in a couple of areas for the thin disk - less rounded corners for example. I also changed the brace a touch, making it slightly larger on both sides and braking each end at a 90, so I could spot weld it to the main piece, rather than welding edge to edge (if that makes sense to anyone).
Let me preface by saying that we're not going for a high end system here. I just wanted a little more grunt on the bottom end, it's not 1994 and I'm not trying to impress anyone but myself. Furthermore, if I DID want to build a proper system, the sub wouldn't go at the very back of the rear quarter panel. So, I originally planned to use the CV VPAS10, but it was out of stock when I went to order, so... I happened to glance at the Boss10. I usually skip on by Boss, but I noticed something: it's he same form factor, and the exact same plate amplifier as the VPAS10. There are minor cosmetic differences and the speaker itself may be different, but I'd bet good money that Boss and CV are owned by the same conglomerate at this point and they're being built on the same line. So, saving $60 off my original plan, I went for it. Along the way, I also replaced the cracking factory sound deadening in the quarter panel, and stuffed the area with automotive Thinsulate. Before and after on the insulation was NOTICEABLE. Much tighter overall sound, and no more sympathetic vibrations, absolutely worth the effort.
End result, honestly, pretty good. I'm still playing with tuning the crossover vs the other speakers . I think to be truly happy, I could use a bit more low-mids from the door speakers which would allow me a slightly lower crossover point, but I'm nitpicking. I can listed to what I want without feeling like something is missing, and I really don't have much into the whole project. Calling it a win!
Forgot to share my finished product. The design provided by @I Lean was perfect and I outsourced the cutting to SendCutSend for ~$50. Powder coated with some other things to make it pretty definitely not necessary. I did have it professionally installed because I also had a backup camera and remote locks added.
For me, this really 10” sub boosted my missing (none really) low end and overall sound stage. Very, very satisfying to my untrained ear vs. my newer vehicles. My door speakers had been replaced by PO and seem to work well overall and fit within the OEM covers, so no need to go bigger if you simply want good sound and keep factory look. I also upgraded head unit to Sony XAVAX1000 from and older Alpine, so not sure what impact that had if any. Overall super happy and with new clips (red ones) there is no panel rattling at normal/elevated volumes.
View attachment 3955895View attachment 3955896View attachment 3955897View attachment 3955898
Pretty dang cool how does the cargo panel look? How much did you have to modify it and how badly does it rattle the cargo panel?
For mine, I didn't modify my side panel at all. It fits back in it's stock location just as it always did. Zero rattles from the speaker. (other rattles other places, but not from this. ;) )
No mods necessary to the interior panels, though I have considered opening it up for a larger speaker grille. I had some sympathetic rattles in mine, but they all went away with the addition of Thinsulate, which improved the sound overall, considerably.
