Went to a dealer today while traveling; got new studs put on a drive flange; mechanic came back and said that I need front pads (I do). I say OK, go ahead, I'm traveling, the car is full of stuff, and it's only $80 on top of the other work, the front wheels are already off--; mechanic comes back 10 minutes later tells me I have a stuck piston; 1 of 4 stuck; will not push back. He showed me the caliper; thing is, he was using a C-clamp and said he had pushed them back one at a time. While I stood there he had the C-clamp in the stuck piston and showed me that it would not go back. He then beat on it a couple of times to show how it was stuck, but he never opened the bleeder valve or took off the hose.
The pads were very thin, maybe 2 mm, and the little wear nubbin had just started touching the rotor. Both pads are wearing evenly, and the vehicle does not pull to one side or the other; tracks perfectly also.
Question; the process I am familiar with is that the pistons are pushed back two at a time while the pads are still on and using the rotor for a fulcrum?? Or, using the Toyota SST that does them all at the same time?? (never seen one)
I always thought that if you pushed the pistons back one at time, you were likely to get a stuck piston??
So here is the question: is this mechanic stupid, trying to pad the bill with unneeded repairs, or do I really have a stuck piston??
I did not have them do the work, just put it back together and drove off; still stopping and tracking fine.
Any suggestions or thoughts would be appreciated ; I am on the road with a very slow connection.
Ned
