Strange water leak/Puddle
Canada?
hello all,
I just went on a 300km drive to another city. After I parked the car, there was a huge puddle of water, under the passenger side front, with a constant drip.
The fluid was water, my guess is that it has to do with condensation coming from the compressor or AC. The AC was not on, I had the unit set to heat and was alternating the slider between half way to 70%.
I'm confused as I haven't encountered an issue like this before.
Should be easy to identify the liquid is NOT coolant by the color. It you still are unsure, turn the A/C on full with windows open and see if the same spot appears.
This is a picture of the puddle, and the leak.
El hombre is correct, it's not coolant or anything engine related, as it's not a fluid but seems to be excessive condensation.
I found another thread, correlating that this may not be a malfunction, but normal. The volume does seem excessive to me.
For more info, I did have the heater on with the defrost "AC" on. Could an overcharged compressor be causing this excessive water release? Or is this normal?
Normal w/defrost(A/C) on.
