Stock spring help!
Wisconsin
background-
busted one stock rear spring when wrap bar broke. got some springs from a 79 and threw them in.... waaaay too much arch!
rig- 78 fj40 SOA
question: what leaves are the most influential on the height of the spring (ie "take out 3rd leaf to lower truck more"). I need these to be near flat when at operating height (like the front) and was wondering if anybody knows the best way to do this.
thanks in advance!
-Max
Stock springs shouldn't be that hard to come by. I would just look for another set of springs.
I wouldn't want to take leafs out of a stock spring pack on an SOA rig. The stock leafs aren't that thick to begin with, and the SOA preloads the springs a lot more than they were designed for.
My .02
Best
Mark A.
If you've got more arch in a set of stock springs than you want for your SOA... Just wheel it a little with some weight in the back.. They'll settle. Count on it.
Mark...
$50 minitruck shaft vs $400 high angle......lets see............:D
also, i have access to a 50 ton press and as far as the springs getting preloaded to much....i have a completely badass traction bar.
any ideas about which leaf to remove or flatten first? :D
