Hey man I just installed a new suspension on my 60 a few months ago.thought I might post another ? on work smarter if possible.
When dealing with bushing replacement or other reason to work on leaf springs etc. (this pin in the first picture) is being a pain in the @***, while not easy to see , that circular lip on the back side of that bracket that seats into the OEM bracket from the frame has become near mission impossible to get seated.
This is the driver side.
I took the rear portion of the leaf spring loose and replace the busshings there and put things back together but loose, then I started here on the front side. Getting this pin to align properly from this angle of view has been *#&#^. I have the other side tight (I've not started on that.).
(1) should I do the front side first and get it seated then do the rear side of the leaf spring?
or
(2) should I loosen up the passenger side bolts in the hope I get some more flex to allow me to seat this pin?
Seems no matter how I move the axle up or down or forward with a hoist..... I can't get the orientation right to set the pin.
hope what I'm saying makes sense....I'm going to post over in the MS chat section to .....to see what their thought might be.
I did not loosen the ubolts and don't plan to, these are the heavy springs and while it sounds a little stupid, getting enough flex here has become a challenge to get that pin to seat properly without screwing up the bushing etc. As noted...I just have one side of the rear leaf spring loose (dirver).
Appreciate feedback
ok,Hey man I just installed a new suspension on my 60 a few months ago.
It’s a pain, but it’s just the angle to get that pin in correctly.
Call me if you need help!
Joel
615-512-3106
Yes you should do this end first and then do the shackle end second. After that is the Ubolts and tighten that to connect to the axleok,
When I installed all this new ...was no problem , but as noted this one pin is fighting me. at least for now...if I move forward...then angle gets off top and bottom or same if I try and move up or down the front to rear angle gets off. I'm sure its related to the angle of the leaf spring (in part). I have the heavy springs which might make things more painful .
Right now I'm thinking (1) maybe I should deal with this pin first and the rear pin second (2) need to loosen the stuff on the passenger side to get some more flex.
Well, in that case, there is so much pressure on the spring with it being connected below the axle, and to the shackle side, when you remove that pin, it probably shifted the position just enough to where it will be very difficult to manipulate that with everything else connectedI'm just swapping bushings, so I've not touched the ubolts. Not replacing the spring packs / leaf springs. Just replacing the bushings and pins etc.
I agree in principle... if the ubolts come loose then more flex in the game.Well, in that case, there is so much pressure on the spring with it being connected below the axle, and to the shackle side, when you remove that pin, it probably shifted the position just enough to where it will be very difficult to manipulate that with everything else connected
@Elbert it is aggravating man. There is just a high chance of anything shifting when you loosen or remove stuff. My vote is to get those Ubolts loosened also from under the axle. You don’t need to remove the leaf spring from under there, just get it loose
Wow, that is a very ample supply of empty totes on the shelf ready for your dozen needs.
Next time you replace your spring bushings ... Look around for an opportunity to borrow a lift. I have found the lift affords me room to work and options/ability to apply leverage where needed on this task.
www.empireabrasives.com
