Steering Stabilizer Help.. does this look right
Texas
lots of play in my steering
Tia
Can be due to lots of different things. have someone rock the steering wheel back and forth while you put fingers on all the different places like tie rod ends, panhard ends, radius arm bushings, loose wheel bearings, etc. can also be due to bad settings on toe-in, caster, loose/worn steering box.
Could be way off, but thought the steer dampener was just that.... dampening. The pics looks correct, but wouldn't think a dampener would solve loose/wobble/etc steering. Guessing something is worn out or loose.
Have you checked all the bits and bolts for the knuckles and your tie for ends?
As others have stated, the damper will not be the source of play in the steering system. It would be helpful if you clarify what changed before and after the lft. Did the play actually increase, or did the steering just get worse? A 2" lift with no caster correction will likely result in the truck wandering.
It does look like your damper mount, however, has a bigger gap to the relay rod than normal. The "shoulder" on my is almost (but not quite) flush to the relay rod. I'd check that yours was torqued to spec.
A gap in the shoulder of the damper is correct for modern OME SD24 steering dampers, trying to eliminate said gap will likely only bust the pin in half. :D
As for the play, start the vehicle, have someone shake the steering wheel back and forth vigorously while keeping the tires as stagnant as possible. Start at the top (column) and work your way downward.
What was done to correct your caster during the OME lift?
Shake the wheel and find the play.
You still haven't addressed what was done to correct the caster?
steering got worse after the lift was installed , about 2" left and right in "play"
A suspension lift is not going to introduce "play" into the steering linkage. Either there is slop in the joints or there's not. This really isn't complicated.
