Steering slop
I just purchased my first FJ 40.:cool: It is a 1973 FJ 40- mostly stock. Exceptions being: after market header, Elect Ign, and an auto locker in the rear. The one question I have is - what is a normal amount of steering play that I should expect? I have about 3-4" of play in the steering wheel before I get movement in the front-end. That play coupled with the locker in the back can make for some interesting handling characteristics. I was not able to find play in the tie rods when my dad moved the wheel for me, so I suspect that the slop is in the steering gear. For a weekend driver under 50 mph, I would like to tighten things up if possible, but I also want to be realistic with a 32 year old TLC.
Welcome.
Look at the bellcrank out front, and see if there is up and down movement here. There should be none, it should only pivot on its own axis.
Are you running longer than stock shackles up front?
Have you verified that the steering wheel moves and the pitman arm on the gear does not move the same amount?
Good luck!
-Steve
the steering is overall crappy i think you can tighten it from the steering box under the hood its a BIG NUT in a square form you can miss it adjust until you get the best outta it and also lube all the fittings on it its always a bit easier to steering after i think and make sure the steering box is filled up
you may also try replacing your steering stablizer i dont kno thats bout it besides going ps or GOOD STEERING ARMS OR SOMETHING :)
The normal you should expect would be no slop in the steering. In addition to what the good folks above said, just take your time and look at all the front end parts while having someone move the steering wheel side to side.
The bellcrank that Poser is referring to is also known as the center arm and yes it is known for wearing out and giving lots of play. It can be rebuilt with a parts kit but it won't be long before it needs it again.
Just do yourself a favor and remove the whole steering system and get power steering, it'll save you a lot of headache.
:beer:
Oh and welcome to MUD :flipoff2:
If you're not ready for the $$ of power steering (which is BTW, money well-spent), Mark Baker (Coolerman) has a step-by-step write up on the steering linkage and steering box repair, on his pages 21 and 21A, and the other pages of his site have a lot of good info too:
http://www.globalsoftware-inc.com/coolerman/fj40/21.htm
I just readjusted my box by reshimming and it worked great.
The center arm is a common problem and you can get a rebuild kit pretty easy if it's worn beyond the adjustment stage (very possible). I don't know what OEM kits run, but CCOTs has them
http://store.yahoo.com/coolfj40/cenarrebkit.html
Good luck!
Slop in the steering box is a possibility and it is usually due to worn bushings on the sector shaft. Rock the steering wheel back and forth while you look at the end of the shaft (where the Pitman arm bolts on with a big nut). If you see any back and forth motion other than rotation of the shaft, then the bushings are worn.
Tightening the sector shaft adjuster on the box can make it feel like there is less play, but it does not compensate for wear on the bushings and you can end up cracking the box casting if you tighten it with worn bushings. If the bushings are worn, replace them.
check the rag joint as well mine was ftorn up and i could watch the wheel move and the movement end at the rag joint
The first and easiest thing to check is the rag joint, this part couples the steering shaft with the gear box, pop your hood, and have someone rock your steering wheel back and forth while you are looking at the rag joint. this is often over looked.
Do you need a press for the R&R of the sector shaft bushing? Mine has some slop, and I considered it, but would have to use a socket as a drift, or some such caveman method. My machine shop does owe me a favor, though, and since the bushing is still available . . .
You can use a socket, but it will deform the dege a bit. It is not a big deal,since they need to be reamed to size anyway. I honed them to size using a brake hone. Rebuilding a manual steering box is really tird polishing.
Much appreciated for the guidance. I will give these suggstions a try.
Thanks for the warm welcome as well!
Oh, by the way, I noticed that my old Factory service manual ('66) gives the maximum sector shaft bushing clearance as 0.2 mm (0.080 in.)
Hmmm . . . Eighty thou - that's a lot of slop, let's try 0.008.
I'm glad to say that I found mine OK at 0.003, so my little tird will not get polished, just a coat of 90 wt on the inside, and rustoleum on the out ;-). When I get it running and rolling, then I'll prolly go saginaw hunting . . .
And read up on pulling the pitmann arm if it turns out that you need to adjust the sector shaft shims, the stories are the stuff of legend.
