Steering Knuckle Lubing - What Tool?
Longmont, CO
So it looks like a 12mm is it or pretty close. But good lord, I've put penetrating oil on it and we'll see in a while. Still, I just sense a stripped nut on the approach.
What do you guys use?
If you are talking about the square shaped plug that you pull out to squirt moly grease in, then use a cresent wrench. If it starts to round off, use a small flat jaw pipe wrench to really put some muscle on it. I am also a big fan of PB Blaster (found at Walmart) to help loosen it up.
If they haven't been off in a while you can also try vise grips and a hammer for the square plugs.
Cresent wrench.
I check mine at every second or third driveline lube (every lube I put four strokes from the grease gun in a zirk I put through said plug).
Put a coat hanger or a zap strap in the hole to check the level (also consider that you are checking thick moly grease...hopefully)
For the most part I find it pretty easy to see how much grease is in the knuckle buy the condition of the exposed ball, I find that it has grease line. A healthy knuckle ball should have a coating of grease (not birf soup).
I believe last time I used a 1/2 inch open end wrench, and once the plug came off, I used some teflon tape on the threads.:cheers:
Where is the grease leaking? Are the wiper seals on the outside leaking? or is the lube from the diff all soupy and thick?
Keep adding grease and if they're not leaking they soon will be due to over filling.
X2 on the PB Blaster, works wonders!:D
The knuckles aren't totally sealed. In normal operation some grease seeps past the wipers and grease gives up it's oil, so replenishing it is good maintenance. IIRC my LX owner's manual mentions checking it every 20K miles.
I find a hammer useful in removing the plugs. Some solid taps straight on top of the plug, then using a punch, hit the side, wrench flats. The vibration helps the penetrating oil soak in and loosens the plug.
If the steering is turned fully to the side that is being worked on, using a flashlight, the backside of the birf, outside of the knuckle cavity can be seen through the plug hole. If it looks empty I add a tube, if it looks low 1/2 tube. You don't want it solid full, so I drive the rig for a couple of weeks and recheck. I look to keep it about 1/2-3/4 full.
True, oily balls are good, dry balls are bad. If they haven't been washed and you look closely, often can tell grease level by the grease buildup line. It will be thicker to the grease level, more oily, thinner from there up.
Make sure you're turning it counter-clockwise:flipoff2:
Just wanted to close the books on this; I ended pb blasting 3 times over the course of a week and then using vise grip. Fellas, we're all men here and some of us are stronger than others. I've lifted weights for 25 years and I'm a strong cat ... I ended up with feet and head wedged against each tire and applying as much leverage as I possibly could to get that thing free. Veins popping. Oh my. I'm sure nobody has ever turned those things. I'm sure that is why I needed long/short axles and two new birfs when the thing was rebuilt.
I love the input on using a zip strip to check it. Lots of good input here.
Thanks,
Paul
I usually resort to my small pipe wrench for such pain oin the ass jobs. If you get it gripping nice and snug it wont tear up the head of the bolt and you can slide a small pipe over the end for leverage.
Also works good for getting studs out if you snap a bolt... if theres enough stud exposed.
D
Evidently, whoever was the PO of your truck never removed those plugs. When you get your axles repaired, make sure you put some antiseize compund on the threads.:wrench::hillbilly:
It is a square plug, 12-point socket (14mm IIRC) works great. (Not many applications that 12 point sockets come to handy...)
Mine was pretty rusty when I did the first birf job two years ago. I had to heat it a little to finally get it out. Once it was out I chased the threads and installed new plugs. Haven't needed to use anti-sieze, but that sounds like a good idea, especially if you live near or wheel in water a lot.
don't forget to clean the area around the plug very well before opening it up. You don't want grit to fall in there.
I use a cleaning wand running off my compressor with some liquid cleaner. Works wonders.
Don't mean to steal the thread. Last time I tried with my flex hose grease pump, the air pushed all the moly back out after I stopped pumping. (I guess one way to comfirm that my inner seal is still good. :rolleyes:). Anyway, do you guys switch to a skinnier hose which allows you push it all the way in? (mine is actually bigger than the fill hole). If so, where do you buy those hoses?
if it is squirting out, it is probably more full than it needs to be. 1/2 to 3/4 full is plenty.
I just smear some moly on the threads when I put them back in. seems to keep them from seizing
used to struggle with same issue. The zirk coupling at the end of my flex was almost exactly the same diam as the hole. It would get sorta stuck in there enough that the pressure would increase and when I removed it the grease would push out.
Now, I just unscrew the coupling from the flex line. The diam of the remaining thread is small enough that there is no longer that issue and even better, I can push the hose far in, so fill it more.
you could also get one of those fattish needle attachments, not the real hypodermic thin ones that would take forever to fill the knuckle up enough.
Is this the square bolt next to the abs bolt that you are talking about?
attachment.php
