Dear gentlemen, your help is needed again please
My question now is about front axle and front suspension and particularly steering knuckle and axle shaft. The manual says that I have to measure the difference between two lines that are scribed by the tools that are placed in the centers of the steeping knuckle and the axle shaft and then MINUS 3mm and as manual says that would give the thickness of the lower shim. What about if my distance is less then 3mm and actually was 2.65mm? If I would minus 3mm from that I would get a negative value (-0.35mm). I was trying to use some logic there but failed to do so as I could not see any reason why there is used 3mm and not another value? and why I have to minus those 3mm from the difference between two lines.
Thank you in advance.
