Steering knuckle centering
As PH said, if you are rebuilding an axle and not swapping knuckles from another housing, just reuse the shims that you took out. The centering tool is needed when swapping say mini knuckles to a 40 housing.
or six shooter knuckles to a 40 housing...
awesome. Thanks guys, I wanted to get in there and see if i need to change the axle seal, brushes and all that, at the very least see the condition of the inners and change out the grease for peace of mind. Seems like a waste to get all the way down to the spindle housing and then stop.
This question is to the attention of GRM. I am also going to make a Knuckle centering tool
What I plan is this.
I will purchase a hollow Brass Rod about 15 inches long with outside diameter approximately equal to the Axle. Then I will make two Nylon Bushes about 3 inches long with a collar in each & holes in middle exactly equal to the outside diameter of Brass Rod. One is to be exactly slid into the Differential side hole where the Axle Seal is there. Other will exactly slid into the Spindle hole.
Now, when the two Bushes are connected with the Brass Rod,everything theoretically going to align.Spindle will be moved to the Knuckle & Shims are added/removed until fastening Bolts exactly mates Knuckle and Spindle. Is now the Axle centered ? No messing up with the Vernier Caliper !
Correct me if I am wrong. Kindly post more pictures of you Tool
I may haver an answer to the negative number mystery. I just got off the phone with a friend who encountered the same negative number problem.
Let's see if I can explain it. When using the steering knuckle centering guage make sure the knuckle is in the proper upright orientation. If you scribe a line on the gauge that is installed in the axle housing and then install the gauge in the (upside down) knuckle and scribe a line a negative number will result. This is easy to do if you are working on a bench away from the axle housing. What has hapened is that the gauge has efectively been flipped over when scribing the lines.
The 3mm has to do with the angle of inclination of the centering guage rod and the lines that are scribed around it in relation to the true center of the axle shaft.
Also my centering guage has an adapter that slips over the scribing (pointy part). That may account for different opening sizes?
Who knows if you're still active here, but Eureka!!! This: "The 3mm has to do with the angle of inclination of the centering guage rod and the lines that are scribed around it in relation to the true center of the axle shaft."
This is the answer I've wondered about! Makes total sense! The scribe portion of the SST is not perpendicular to the main rod, so apparently Toyota figured out that the 3mm deduction was needed. I'll sleep much better tonight.
Thanks!
