Steering gear box rebuild
But the good thing is to learn from it. I know more than I knew last week.
Job is done and the rig is on the road again. I’d like to thanks everyone for their input in this thread. Following the steps made the job way easier.
Outstanding!
REASSEMBLY
Step 7: Reassembling the worm gear valve body assembly
Press the input shaft oil seal and bearing back in. Make sure they seat properly at the bottom of the valve body housing. A large socket (~24mm), wooden dowel, or brass drift are all equally useful for this.
Put the input shaft back in the valve body housing. Use plenty of ATF to ensure everything slides in properly, and be careful of the Teflon ring if you replaced it. Then put the needle bearing and preload nut back in place.
Tighten the preload nut until the match marks line up. I tried increasing the preload but the really isn’t much room to play here and I ended up going back to “stock”
Install the lock nut and align it with the other match marks.
Now comes the tricky part, getting all the ball bearing back in the power piston. Put the worm gear shaft back inside the power piston. You should be able to get most of the ball bearings back inside the two holes by turning the input shaft back and forth. Make sure you keep the piston close to the valve head so the balls don’t fall off either end of the worm gear.
Once most of the balls are in the housing, grab the two halves of the metal tube and some sticky moly grease. Line the inside of the tube halves with grease and stick the balls inside the tube.
Put the other half of the tube on top of the first
Push the assembled tube back into the piston until you can get the metal clamp back in place. Install the two screws.
Step 8: Reinstalling the worm gear valve body assembly
Now that the worm gear valve body is back together, reinstall it into the gearbox housing. Use plenty of ATF to ensure nothing binds, and be especially careful of the Teflon ring. Make sure it isn’t caught on the edge inside the gearbox.
Install the four 14mm bolts and tighten them down to pull the valve body into the gearbox
Now reinstall the power piston plunger and guide. More ATF to lube the O-ring here too.
Step 9: Installing the sector shaft
Install the new O-ring, Teflon ring, metal ring, snap ring, and oil seal. Pay careful attention to the orientation of the oil seal.
Centre the power piston in the gearbox housing
The FSM recommends putting some moly grease on the teeth prior to installation. Install the sector shaft, making sure the teeth are centered on the power piston.
Put a new O-ring on the side cover and line it up on the adjusting screw.
Use the adjusting screw to pull the side cover down. Note the direction of the threads (lefty loosey in this case)
Install the four side cover bolts and tighten them.
Now the box is 99% back together, and you need to set the preload. It is possible to use a special SST socket on the input shaft to attach a dial torque wrench, but most of us don’t have access to either of those. I found that the difference between good and too tight was easy to differentiate while turning the input shaft back and forth from lock to lock. Adjust the screw 1/8th of a turn at a time until you get to too tight, then back it off a bit. Install the new seal washer and the adjusting screw lock nut. Be sure that the adjusting screw doesn’t move as you tighten the nut.
That’s it! :cheers:
A few power steering related links:
Pump
Power Steering R&D - https://forum.ih8mud.com/80-series-tech/409610-power-steering-r-d.html
Toyota OEM PS Pump PIS and GPM Ratings & Hydraulic Winch - https://forum.ih8mud.com/80-series-tech/367350-toyota-oem-ps-pump-pis-gpm-ratings-hydraulic-winch.html
Power Steering Pump and Hose Replacement - FAQ - https://forum.ih8mud.com/80-series-tech/201920-power-steering-pump-hose-replacement-faq.html
Gearbox
Power Steering Gear Box 105 Series Sector Shaft/Pitman Arm Upgrade - https://forum.ih8mud.com/80-series-tech/336799-next-list-rebuild-ps-gear-box-new-sector-shaft-pitman-arm.html
FJ80 Power Steering Pump & Gearbox Rebuild - https://forum.ih8mud.com/80-series-tech/98211-fj80-power-steering-pump-gearbox-rebuild.html
Cracked Frame - https://forum.ih8mud.com/80-series-tech/273182-cracked-frame.html
Tightened steering nut - big benefit!! - https://forum.ih8mud.com/80-series-tech/330999-tightened-steering-nut-big-benefit.html
Fluid cooler
Power steering cooler upgrade - https://forum.ih8mud.com/80-series-tech/20738-power-steering-cooler-upgrade.html
Power steering cooler Install - https://forum.ih8mud.com/80-series-tech/343463-power-steering-cooler-install.html
Heat Sink power steering cooler install - https://forum.ih8mud.com/80-series-tech/280386-heat-sink-power-steering-cooler-install.html
Me and my Behemoth are absolutely forever thankful for your writeup!
Absolutely Grand!
I tried to read through the 15 pages of great information to see if anyone discussed replacing the needle bearings in the box? I didn't see anyone discuss.
I have purchased the needle bearings and am going to attempt to press the old out and install new. Those little suckers are expensive! If anyone has replaced the bearings will you please chime in and let me know if there's any magic tricks I should be aware of or any pitfalls like dumping bearings all over the work bench?!
This post was super helpful in getting my gearbox rebuilt.
Got back on road and all is well- except my steering wheel is ~70deg off center to the right. I know the sector shaft and pitman arm have the markings aligned, so I am assuming the way to center the wheel lies in disconnecting the steering shaft (which I didn't mark in any way when initially removing), centering, and reattaching?
Someone I know mentioned shifting the pitman/sector shaft alignment, but the markings make me think this is not preferred, even though it seems easier..
that and i know you can turn the wheel by adjusting the drag link end too, but if it drives straight down the road but the wheel is clocked weird i think a spline or two or a few in the opposing direction would help ya— good luck!
What exactly does the SST look like, just a thin-walled seal driver??
It's entertaining listening to that you-tuber, no filter, thinks (and swears) out loud like most of us do (generally when no one is listening).
It looks like the SST might stretch/expand the teflon ring so the shaft can pass through without damage.
Using the procedure in the video it seems like he's effectively using the shaft to expand the teflon ring, albeit at the expense of an out of order install and having to drop the shaft back out to put the circlip in.
I wonder how robust that needs to be. Seems like it might be an excellent 3d printable tool: most people will only need it once or twice and the real Toyota version is probably prohibitively expensive - if it's still available.
If anyone has access to one, a pic or two and some dimensions would be appreciated.
It appears that:
09630-00012 is the complete "Power Steering Gear Housing Overhaul Tool Set"
09631–00120 is the "Teflon Ring Former"
09631–00170 is the "Remover"
Does anyone have photos of the complete set of SST's or (already asked) photos of some of the individual tools?
For comparison, below is a photo of a Power Steering Housing Overhaul Tool Set for a FJ40 (00002-00800)
Wondering if the tool at the top right in this kit might serve a similar purpose as 09631-00120 for the 80 Series??
This video is for a HZJ75 Steering Gear rebuild (similar to the 80 Series box). Start watching at ~11:10 min where he shows the installation of the O-ring, spacer, and snap ring just before installing the "heart shape" Teflon seal using needle nose pliers. No other SST was used for that portion. He later (~26:00 min) installs the sector shaft pushing it through the Teflon seal.
