- Joined
- Dec 26, 2007
- Threads
- 48
- Messages
- 508
I've got a sprung over, cut and turned, Saginaw'd fj40 that doesn't return to center. The steering just stays where you put it even in parking lot tight turns. It also feels like its got some drag in the steering which could be keeping it from returning to center (just a hunch).
It's been like this ever since I did a few things to it:
1. Converted to a low height shackle reversal (which obviously changed the caster)
2. Replaced the Saginaw box
3. Replaced the steering wheel.
4. Removed a leaf from the spring (this shouldn't have any effect).
Unfortunately I did all this at once so I don't know what caused it.
I assumed it was bad caster or maybe a toe problem, but I had an alignment done today and the problem really hasn't changed. See alignment attached.
Also I thought I might have screwed up something (causing drag) when I put the steering wheel on, so I looked at that (the bushing) and it doesn't seem to be the problem.
Any ideas? What could go wrong with the Saginaw box to cause this?
Positive caster should bring it back to center unless something else is wrong right?
