Steering Column Plate
Temecula, California
Take a look at the attached picture and notice how my PO has gooped up the plate.
I'm assuming he did this because there is a leak/hole/etc.. So, once again, I'm having to remove and fix his work.
However, I'm struggling in finding what this piece is called. What is this plate called and/or what are the parts that I need to properly fix this section of the steering column?
Toyota still sells a rubber piece that goes there. Not sure why all that grease is there. Maybe that's what he used to keep the air from blowing through there.!
Thanks for that link.
I've attached the same SOR steering assembly image. For the record, the part I'm looking for is #22 (in the attached image).
The cheapest price I could find was at ToyotasPartZone.com. The Toyota name for this part is "DUSTPROOF, STEERING SHIELD" coming in at around $28 (plus ~$10 shipping)
Toyota PIC Number: 45254
Toyota Part Number: 55122-60021
Is that part number cut out for the column shift? SOR doesn't carry this any longer for column linkage.
I picked one up a few years back. It is formed for a column shift but you have to cut the hole for the shaft. I see no reason why Toyota which redesign it know and make it flat since most the cruisers this will fit had a column shifter.
Here's a an exploded view of the "Steering Column & Shaft" with the OEM/Toyota part numbers.
I'm in need of the Shield and Cover (Parts 45253 and 45254), but both of them are discontinued. If you know of an after-market solution for these parts, please share what you know.
1979371
I have both. Leave me a VM at eight 18- nine53-nine230 and I’ll call you back when I’m in the shop.
