Static electricity & plastic fuel cans
Keep in mind too that gas vapors contain carbon monoxide. When you are filling inside the vehicle those vapors are...inside the vehicle. Carbon monoxide is actually slightly lighter than air so its trapped (dispersed) along the top of the inside of the truck. This affects dogs and people alike.
Pretty sure gasoline vapors are comprised of volatile organics and not carbon monoxide. Still dangerous though. The CO only comes into play as a combustion product.
Was the transfer hose grounded?
It was grounded, but the gas was moving at about 5,000 bbls/hr. Went from the hose to a pail. Some went into a hydrometer, and the excess was transferred to the plastic container. Got, stale day on Maui. Can went up as soon as the product fell into the bottom.
To tie into the above discussion about static charges:
I'm not an electrical expert, but FWIW, before replacing the fuel pump in my 80 I first disconnected the battery then ran a ground wire from a bolt hole in the floor (threads cleaned for good contact) to a pipe in the ground about 15 feet away. From the above discussion it seems that if the tank itself was not grounded to the body (rusty bolts??), then the ground wire I rigged up might not have drained off static charges in/around the tank?
Any thoughts from the experts on grounding the vehicle and/or the fuel tank before opening the tank up??
As long as there is no ignition source, you are fine. Once the static charge has been dissipated, or better said, once you have equalized the potential, there is no hazard of an arc. Difference of potential is what, generally, creates an arc. Another is the generation, supply and control of energy. So, discharging helps but, if you have not also disconnected the battery, there is a chance of a short and hence an ignition source.
While working on your fuel system it is wise to have a good strong fan nearby blowing fresh air over the area you are working and, DO NOT do so in an enclosed garage or space. Repair garages that "declassify" the work areas use supply fans that "wash the floor" to prevent pooling of vapors. The supply air is brought to floor level and exhaust vents (rarely fans as they would have to be explosion proof) are also placed at floor level, at opposite ends of the space, to allow air movement across the floor. This is not a popular option where living in cold climates and is quite often disconnected as comfort becomes an issue. Obviously not safe. Additionally, the adjacent rooms to the repair garage have to be under positive pressure compared to the repair bays. This will continually push fresh air into the occupied rooms or offices and not allow flammable gasses to accumulate in them.
So, setting aside the issues surrounding fumes. Setting aside the issues associated with interior vs exterior mounting.
Regardless if a plastic can is mounted inside vs outside If I just want to manage a potential electrical charge from refueling and leave the can mounted in place. I routinely carry jumper cables. If I clamp one end on the can handle, and lay the other end on the ground. I should be able to manage any electrical build up ? Or do I need to clamp the other end to the frame of the vehicle ?
All I can say is if the can is plastic, I’d 100% set it on the ground & keep the metal nozzle in contact with the container when fuel is pumping, since during transfer is when you’re building any possible static.
In the refinery we had mini-versions of a battery clamp/grounded cable to the steel structure of the process unit we filled nonene into sample bottles that were samples for the lab/quality control.
We were filling little aluminum quart bottles like white gasoline for a campstove, and each had a flat tab up by the mouth welded by a refinery mechanic expressly for the purpose of clamping that ground to.
Nonene is far heavier a hydrocarbon (c9) & used to make plastic, OSHA rules are overkill but despite harder to ignite we had to use the ground clamp, no excuses.
If you ABSOLUTELY think you need to fill your plastic can in the interior of the vehicle/on the swingarm, I’d personally open a SS hose clamp & wrap around the handle & tighten it down. Then use your battery cable to that hose clamp & stand/keep your toes on the other end while it lays on the ground.
That way you are really grounded to earth if the nozzle bumps away from making contact while pumping, and that’s when you get that static arc.
Personally after working in a refinery, I wouldn’t do that at all - but that’s the safest answer I can give for your question if you choose to do so but we would call that decision “at risk behavior” & that’s where most accidents started from.
As a precaution I also would have any living passengers (people or animal) - out of the vehicle while pumping if that can is inside, in case that arc should ever happen.
