Starter wiring help
So... are you saying the starter doesn't turn over?
Do you have an indication that you are getting power when you turn the key?
Yes the solenoid clunked like it was popping out but the starter was not turning over. Nor did it try. Although it did briefly turn the motor then stopped.
Could be the starter... but see if it's seized, first.
As @Curt said, "Using the a wrench on the alternator and pressure on the belt, or jack up back wheel stick it in 4th and turn.".
I always use a socket on the alternator pulley... no need to jack up a wheel.
If you need another starter... Mark (@65swb45) or Georg (@orangefj45) can probably provide a good used one... I would go with a gear reduction starter (GRS) out of an FJ60, if it will work for you.... if your engine is a '78 2F, a GRS will work fine.
If you are using a '70 harness to connect a '78 starter, I can't help... I'm not familiar with how '70's wiring differs from '78.
But, if your '70 harness doesn't have a fusible link, I would install one... don't want a harness fire.
Just so you know, or anybody else out there. A gear reduction starter will work on an F engine also, as I have done this. If pics are needed for the electrical hookup I can try to post a pic (not computer savvy).
Don
Looks like the engine turns. I removed the starter and battery tested it. Solenoid pops out but the starter doesn't turn. I broke down and bought another wiring harness for it and now need a starter. Hopefully I can rewire this thing and get it on the road.
Thanks for the referral Danny.
Chiro, I will be back in the shop Monday. I'm pretty sure the price of the starters is listed on my website. Hth.
No no no !
White/Black is ground! If you connect a white/blue wire to ground you will have an INSTANT and spectacular harness fire! Especially if you do not have a fusible link installed!
The starter as shown is hooked up correctly IF the wire connected to the S spade terminal on the starter is Black/WHITE. It's hard to tell the color in that pic. However, since there is only three wires coming out of the harness, I'm pretty sure it is Black/White.
The large Black/Yellow wire (depending on what year this is) goes to either the igniter, the ballast resistor, or straight to the coil + terminal.
The green wire on the starter is for the ballast resistor which you do not seem to have. If you did there would be TWO Black/White wires, a small gauge BW wire which would connect to the green wire on the starter, and a larger gauge BW wire which connects to the S spade terminal.
I have a 1978 FJ40. Trying to get my wiring figured out here for my GR starter. I have two b/w wires. A large one and a smaller one, smaller one has the red connection attached. Which one connects to the S spade on the starter? I used my volt meter to check and see which one has power when the key is turned to on. The small white wire has power and the larger one does not. Here is a picture. My plan is to run the larger b/w wire one to the S spade on the starter and run the smaller b/w wire to my DUI dizzy.
AbIxBppKmSRud8HdVkP5QmwKw1w2XnFSV049eMI2UMsizNrroHWBNcVB9e18nLc9jlZlTb4_JqNxti-g3L72Fl6BQ1ewS4Zeqha-fBYNUhJyL2OuLIgJFfmnrWo7kesUw7FYC2ZT-RdbAObavEfjcYWrQSj2rmuILMi88LqwTSlzxcNadpOVdDSDDDRWQoYf8lnOMh07xeDUJx2x0VhHkjX-mOVpdRSQ4iiRyX2YkTNbGpWJUjBfRPnYtksqy9QVyXi5EI97AdwAgTC9MzLMwcliy5OpT33OBZvM3ykLJMxH5ZBmUC-DCTceleVQHOkybgy_-APVCg_GS99oiuHUJi88C5seTBF3enOkR8a5f8jJFTmOoaqAOxtFJeVdOEvGLgu6TBMtZqT4qERWTbgkl-_rQ1c_hI7zEY6MsJyjxaR_uu4U8tF3-JhvgdB_2wucTjkd6cBboboGqP89DZP191zHKg-xyZwCJaPYi6ocnGhHyukH-fYpyXZmPPbkCFmiv6uNTagIKkMMm7n1R3sb4w7EOR8brCPttUUBvbkgx0h0aTV0Fa4wACGAyU9r0uOC3mkljxToFk3qyxMVft2jqU1NpCiufSgk2ITIugetU38C04BMWJ79gA=w694-h925-no
It's supposed to be the wire that ONLY has power in the START position, not the ON position.
If this is not immediately obvious, you should not do this job yourself.
Good point Mark, that makes sense, thanks. I am not a mechanic here so I am learning as I go here. I am trying to fire up the engine for the first time since the frame off tomorrow. I would assume that if I do not have the wire hooked up to the starter, I could turn the ignition to START without any other issues and I should be able to see if it has power then.
It looks like your starter is cut, the one with the tag.
Starter should be larger Black Yellow wire, may look white from age. With key in start this should have voltage.
What kind of dizzy is installed?
The dizzy is a DUI made for the toyota. I just tested the larger 10 or 12 ga black and white?/yellow? wire with the key taped down to START (since I am running solo) and sure enough it has 11.78 volts! Hopefully I will be turn'n and burn'n! Thanks for all the help!
a4vvcZQTEgNptU9dTKpyROSaa1Ns7kji8xWVyQ6cqg8auwJsWqHjLhpS4EXnbclD_g4alqbVpk0JjJOJlO7FUrcTOZc9ZhkgLv51ZLntshMvNb4RUGtHHxNIjxebLa4DuXiZN88Y8RtPCbpkKy6vhNBUHSbhe3HaTXfkaaxTieAPn6DX7Udo0X04iQWUMdWZRZbsN7-91ma4mRK9Ify4vYrn0Owy5rgpCpObpfWXJyQ7j0Zgs-RCYfWB88ve03iTkna_r1nt3U3JEsEWu-bxSBjKZ2Q6CCTBCfVkcxxtZrD1h4iRCnbssOP1ENjsLn6OQkmy2DYSxS1rVzjcZDYZfyOW0GzEEGcWHOT6YULF_4jNX7zo3yHzZBxFGamR0NzY5Y9XzL7aoumSO5jExlfoBm9rIFmqZqoatO1yXOLpqJsduTpNc_RHg38S3NS4q6q_YDWD8tyJz5BwXMxP-r5xPk4JCFlg4uI7fBmhxBKrjoauF7w0wItql4V3yIwKnMjN1PumT1pW5FN-v1h7h0i6XZ9ZYLcX-_8pkvpHmawdMPsKc6dBFn3aTU839TmlRuzvf2VkY9cKhiQMJCHd0Yq3hN2WQ9qYluEkkXVmBmHl2hKcrlyS2r6j0Q=w694-h925-no
Below are pics of starter in my 1981 FJ40. I can’t be sure starter is original but quite sure wiring harness is.
I can’t seem to find a connector that fits the small black wire coming off the starter. I believe @Coolerman mentioned this wire not necessary on late model harness.
Can anybody confirm?
Last picture shows Black/Yellow wire coming off Starter housing grounded to frame. I only used this cable because it was available. Is this ok?
View attachment 1654336 View attachment 1654339
IIRC, the exciter wire was only used between 73-78. The fact that your replacement starter has one is not definitive. The advent of the electronic ignition system in ‘78 pretty much took care of the reason why they had the system in the first place.
FYI I do have the mating connector if anyone needs it. Part #FLFP16.3W
That BY ground is correct and is one of the few times Toyota deviated from the normal color code. Black/Yellow is normally key switched power. Don't know why they did not use the normal White/Black for that ground... Maybe they though folks would get it confused with the White/Blue used for always on power to the fuse panel?
@Coolerman Ive got a situation going on with my Starter.
I put together a homemade Bump Starter to seat my distributor, but when I tried “bumping” the starter the solenoid whirs and spins but starter does not engage.
@LAMBCRUSHER suggested my battery might not be fully charged. Any other thoughts?
Is your homemade bump starter sending full battery power, or resisted power?
I’m not familiar with ‘83...
Is your fat (8-10ga) BY spliced into a fat pink Yazuki (sp?) resistor wire?
The skinny BY is unresisted (full battery power).
So my homemade Bump Starter is running from Black Wire S terminal to the top post on starter, which is Big Red Cable that connects directly to the + Post of the battery (and is disconnected until I touch post)
The wire I used is admittedly very small gauge.
Doesn't need to be too big. OEM is 12ga will be fine for the short length you have. Make sure the battery is fully charged. The atrter will not function below about 11.5 volts.
Other causes could be that the solenoid is not working correctly.
