Starter wiring help
Assuming you have Toyota OEM electronic ignitions, Here’s how my remote starter connects... use my scribbling or don’t.
I connect remote starter positive to battery+ (easier to reach) and remote starter negative to the male blade terminal on the solenoid.
Disconnect the negative side of your coil.
Tranny in neutral, parking brake set.
Sorry! Here’s the picture
Took battery to get checked out.
Was told it was very weak, so I replaced Battery.
Went back and tried to Bump Start again. Found S terminal and ran jump wire from it to + battery terminal. Now started clicks but does not engage. Bad solenoid?
BTW, my S terminal wasn’t visible in prior picture, hidden by Red Power cable.
To be clear... your grounds are good, clean and tight, right?
If the grounds aren’t good, you may not be getting enough juice, at the starter, to cause the starter gear to engage.
I recall your starter grounded to the frame, near the clutch slave... is it a ground to bare metal and is it tight?
Is you battery- grounded to bare metal, on the frame, behind the front passenger tire? Is it tight?
You might put your multimeter on the starter case (neg) and the battery (pos) and see how many volts you have.
If that’s good, measure again, with pos at the S terminal, after your bump starter.
If that measurement is good, try jumping the starter... e.g. screwdriver or jumper wire, from the battery+ lead on the starter or from the battery.
Does that make the starter engage?
Also, You’re sure your battery+ cable is good, right?
If you have good grounds and good voltage and your starter doesn’t engage, it may be the solenoid.
This thread discusses this a bit... the last post talks about cleaning the solenoid contacts. FJ40 wont start. Starter solenoid question
I'm going to get some Wire Wheels for my Dremel and clean all my grounds, etc.
My frame is powdercoated, is it necessary to grind down to bare metal?
I have a Multimeter but not real proficient on how to use it. How many volts should it show, 12 ?
Bare metal... powdercoating degrades grounds.
Battery+ feeds starter lug.
Measure. battery+ (Red MM lead) and battery-(black MM lead), set MM to DC Volts and 20v setting, to get your baseline voltage.
Once you have your baseline, measure
  • Starter lug (pos) and starter case or case ground lug. should measure the same as your baseline, or close to it (battery is going to slowly lose voltage).
    • Meeting baseline indicates you are getting proper voltage to starter and associated grounds are good. Finished
    • Low voltage could mean something is preventing full voltage to starter. Continue.
  • starter lug (pos) and battery- (neg) should measure the same as your baseline, or close to it. Low voltage, ground is suspect. Check all connections and cables, from battery- to frame, frame to starter
  • Starter ground and battery+ (pos) should measure the same as your baseline, or close to it. Low voltage, ground is suspect. Check all connections and cables, from battery+ to starter.
Edit: the above tests are in reference to your attempt to engage your starter, using your bump starter.
I cleaned all ground contact spots with Dremel (starter to frame, - battery post to frame, + starter lug, and solenoid mounting studs).
I am now able to engage starter by shorting S terminal and + starter post. However, keyed ignition is unresponsive ???
Also hooked up distributor and spark plugs and nothing, no fire. ( I’ll probably start new thread).
Remind us... are you sure you are getting full ~12v to the S terminal of the starter, when the ignition is keyed to Start?
So... you’re saying it’s wired like the schematic fragment shows... there us already a BW wire to the solenoid? Where does it connect?
The loose BW wire has a connector that will slide into the S terminal... right?
Which BW originates at the ignition “s” terminal? That’s the BW you need connected to the solenoid.
Do you have another male blade terminal on the solenoid... besides the S terminal?
How is the other solenoid terminal labeled?
You’ve proven that jumping S to the large positive post causes the starter to turn... yet, with nothing in the S terminal, it won’t turn.
I suspect that loose BW needs to be connected to the S terminal on the solenoid... but, since you already have a BW connected somewhere on the starter and the S is unused...
Find out which BW originates at the ignition S terminal.
I plugged the black/white onto the S terminal on Starter as it just “makes sense” given all of the above.
However, I still have nothing at the ignition.
I just loosened the fuse block and cleaned all terminals with Dremel and some contact cleaner. Checked fuses, all good less 5A radio. I even took fuse block mounting tab to bare metal to make ground contact.
NADA
