Start-up
The Ghetto
When start my 72 FJ40 w/80-84 Chevy 305 conv.first thing after sitting for a long period of time I have to hold the accelerator down above idle to keep it from stalling until the engine warms up. Is this normal?
That might be considering the fact that I have exhaust smoke coming from the pipes from time to time. How can I clean the sumbitch? (sorry this is my first non-fuel injector):D
Mine does the same thing. It's because I have a Carter carb with an electric choke that I'm pretty sure isn't working at all. Do you have an aftermarket carb? When you pull out your choke cable, does it do anything? If yes and no, then you probably have an electric choke that ain't workin'.
Not sure. Maybe I do. I have a Holley Filter but i'm not sure about the carb itself. I was thinking the issue was because of the old engine. I thought old engines did that. That's about the extent as far as knowledge about non-fuel injected engines I have.:o
Had kind of the same problem with mine. Could be a choke and it could be the carb needs adjusting. Had kind of the same problem with one of mine. First thing I did is took it to the garage to get the timing set right and them tune the carb. (Cost about $25)
They gave me the settings on the fuel screws and now I play with it. Mine does much better now but still a little finicky when it's cold but will do. Actually, purchased a TBI intake and body and plan on converting when I get the time.
I don't know about the 350, but on '72 you have to pull the choke until the engine is warmed up
mdjohnsen said:
I have a Chevy 305 not a stock FJ motor. Does this still apply?
That will apply if you have a manual choke. Were you able to determine that, yet? Manual vs. electric (automatic) choke? See my above posts.
edit: Bailey beat me to it.
If you go with to TBI, the intake is different. Also, the what I call the body, looks like the carb you are replacing but different make up on the inside.
They do make plates to put on an existing carb intake but according to a guy I spoke with at Howell, the intake must be for a 4 barrel carb for it to work. (Not sure on that but check in you decide to buy one.)
Buy a can of Gumout carb cleaner and follow the directions on the label.
That will clear up many of the carb problems you might have with almost any carb.
Be sure to hose off all the linkage well.
I do this twice a year as a PM.
Throttle Body Injection TBI.
Basicaly the same as rail injection but straight into the intake manifold and only 1 (2?) injector(s).
Kits are available for the almost any engine. I would think a 305 conversion would be easy to find.
