Square box is the sensor for the auto wipers.What is this thing on my windshield? Build sheet does not mention dynamic cruise, automatic braking, etc. Is it rain sensing wipers?
2013 LX570
2013 LX570
Yes. Unplug if you want to go back to old fashioned intermittent.What is this thing on my windshield? Build sheet does not mention dynamic cruise, automatic braking, etc. Is it rain sensing wipers?
2013 LX570
Hey, I just noticed this when I was peaking under the vehicle looking for the sound of a squeak (likely my BP-51s). Its the line from my LRA tank to the aux fuel pump. I have never really dealt with fuel lines, is this something I can just tighten and check on it later or is it more involved?View attachment 2788891
I was told you cant cut the reflector successfully so I had some small LED lights fitted to improve the lighting spread when reversing.When installing the Slee rear bumper, how does one trim the reflector? How do you even separate the reflector from the housing? Cut the housing as well?
Also, getting the parking sensors into the grommets for the bumper?
I can't say for certain but it's entirely possible if the Slee bumper reuses your existing grommets they are not the same as whatever Slee tested.Yea I can't get the sensors into the grommets and they feel like they want to break
Cabin filter. If you drive past something stinky (dead skunk, cattle farm, oil refinery) you can press it and it'll remove the smell from your interior in about 30-60 seconds.
The grommets did change at some point, they actually got smaller, but I'm not sure when. Possible with the '13 refresh. I bought my RLC rear bumper used, and apparently it was on an earlier truck, because the holes were already drilled, but they were larger. The grommets from my '15 sensors wouldn't snap to fit, they just fell back out. I had to buy new grommets anyway, as most of mine broke when removing them. So I ordered grommets for the older trucks, and they snapped right in. The grommets come already color matched, so I bought all black ones. I only had to paint the noses of the sensors black.I can't say for certain but it's entirely possible if the Slee bumper reuses your existing grommets they are not the same as whatever Slee tested.
I had this issue with my Trail Tailor front bumper... Jason had tested with TonyP's 2013 and the snapped in fine but the grommets and sensors would absolutely not fit in mine without enlarging the holes. Later after I broke a grommet and bought a replacement for my 2013 the one sent was slightly different and was effectively too small for the new hole. I used a bit of epoxy to hold it in place, but I'm 99.9% sure the replacement grommet would've fit into the original hole perfectly. Weird thing is that I now think my original front sensor grommets were actually REAR sensor grommets as the one that broke was one of those slightly angled grommets and not the completely flat ones.
Can you expand on this? Is it simply unplugging the wires right above the box or somewhere in/under the dash? I’d really like to go back to old fashioned intermittents as the rain sensing doesn't seem to work at all for me.Yes. Unplug if you want to go back to old fashioned intermittent.
Unplug the connector in the black box next to the mirror.Can you expand on this? Is it simply unplugging the wires right above the box or somewhere in/under the dash? I’d really like to go back to old fashioned intermittents as the rain sensing doesn't seem to work at all for me.
Separately, what is the range of volume on the Mark Levinson 19-speaker system? It sounds really good when I start to increase the volume but I’m not sure if 40 on the volume scale is middle or in the high range.
Lastly, does anyone have the part numbers for the plastic engine cover “bolts”? I have a few broken I’d like to replace. And maybe the part numbers for the plastic trim pieces under the plastic engine covers that sit on the fender sheet metal? Thank you in advance for the help!
yes, exactly. If you normally run with recirc on, then all this button does is raise the fan speed and maybe redirect air to upper vents only - then returns everything back how you had it after a few mins. If you normall run in fresh-air mode, it does all the above + enable recirc mode.Funny, I never really noticed this button on my 2010 until I saw this post.
I still wonder what it does and how it works. Isn't all of the air filtered through the cabin filter?
forum.ih8mud.com
