Spring Flips
Longview, Texas
I have just about decided that I am going to go with a 4" HFS SUA lift. When I install this lift, I am thinking of doing a rear spring flip to increase my wheel base. Extra length will also help to increase drive shaft lenght if I decided to go with a NV4500 tranny. From what I have read, the spring flip is just that...flip them 180 and install.
Will this work well with the HFS springs and should I flip the front springs as well to maximize wheel base lenght? Will I still get good shackle angle after the flip?
Also, will a spring flip necessiate that you cut and or modify fenders? I think I will probably run 33 x 10.5's
I have searched on this topic but can't find exactly what I was looking for.
Thanks for you help.
I did the spring flip on the rear only, Some will tell you to redrill the center pin so you can have the military wrap forward at the fixed joint, I still need to do this, I am also in the prosess of a NV4500 swap, That extra 4-6" could really help out on the rear DL, I still have a great shackle angle, But I run stock springs SOA.
Fenders will need to be cut, I also welded in some to fill in the front area.
Good luck!
That is sort of ashame to buy a new spring pack , disassemble and modify before you ever install. Guess the only way to get it done from factory that way is to go with a set of true custom springs made from Alcan. Doubtul CCOT would do that for you before they shipped.
if you spring flip, don't you run into issues with the pinion angles (i.e. the pinion points down as the axle down travels) meaning your shaft'll need to take a heap more angle, and the potential to bind and break something goes up heaps?
If you are buying new springs, I assume that you are buying lift springs. Many don't have mil-wraps. They should IMHO, but they don't.
But it's not a big deal to pull the pack apart anyway.
Mark...
Nope. Not a shackle reversal, just a leaf reversal. Iy dorsn't change the way the pinion travels. It does change the caster of the front axle and the pinion angles a tiny bit. Use a slightly longer shackle (same length as an FJ55 rear shackle) and problem is solved. THe location of the axle on the curve of the spring doesn't come into play as the spring comopresses and dropps. Not in the real world anyway.
Mark...
I'm a little confused on where you have to cut. Do you just cut the tire well opening (toward the back) and add fender flares.
The spring reversal moves the axle (and the tires) further from the center of the rig. You need to open uo the back end of the fenderwell.
Mark...
Mark...
yep i knew that it wasn't as bad as a shackle reversal, but i was looking at doing the spring flip on my cruiser, and i was told by a club member not to because he's seen heaps of pinions sheer off due to it
Between the ones I've done for customers, and the ones that guys I run with have done on their own rigs, I'd say that I have first hand and continuing knowledge of about two dozen '40s done this way. Fs, 2Fs and V8s. No problems reported. I have seen one of the rigs wrap the rear springs pretty hard once. But he was strapped to a rig stuck in silt, took out the slack and did a good job of energetically engaging the clutch without spinning the tires (sitting on wet, hardpacked sand). The springs curved pretty badly and I was kinda scared for a second. Of course he was also pulling the front end off of the ground.
That just doesn't happen that often. ;)
Oh yeah... He didn't break anything. :)
Mark...
dammit... i've already set up my mounts and driveshafts to use the other springs... ah well
how many people have actually broken a leaf spring, just curious. i have never seen it personally. well tv doesnt count of course
sorry to hijack
I've seen several broken due to age, heavy loads, big impacts. Only one broken due to spring wrap. (It was a cheapo Tacoma lift spring.)
It's not springs breaking that folks are worried about in this setup. It is that the springs will allow too much spring wrap and that the pinion will bind. Or that the spring will wrap and create wheel hop. Neither is a real world issue in my experience.
Mark...
Why not run 60 series rear springs at each corner? I did my truck years ago and it's been a great swap. Longer springs, softer ride, better wheel travel and articulation, and if you want... a longer wheel base.
~John
Pics available if want... msg me.
iv thought of doing a swap with 55 springs also, i know a guy who has them sprung under on his rig and they seem to be working fine
hey mark would a traction bar help in those situations that the springs are wrapping?
also, i have not seen first hand but my sisters friend busted a spring pack on her h**p YJ a while back...
Ya yotawheeler, thats exactly why you need the traction bar.
I got 45 springs in the back. MUCH softer. Just stick out a little too much in the back, kinda hurts the departure angle. Can't remember how much it changed the W/B, stock front D/S in the rear now. I will soon SOA the rear and mount the shackle higher on the rear bumper. Traction bar required, already busted a pinion before installing a bar.
I fliped my OME springs on the FJ40. No problems. I cut the rear of the wheel well and added TJ flares. Pinion angle was fine. I have not needed a track bar but I will probably add one at some point.
  • Like
Reactions: SMG
