Thanks for all the comments guys. If the pinion angle does rotate downward after the flip (rear springs), I guess this can be corrected some by the addition of a proper degreed shim. Correct??
Also, for anyone who decides to this this mod, is it more common to do the front and the back, or just the back?
I just did this mod to my '77 40 and here is what I encountered.
When installing my new 4" lift springs, I reversed the rear springs giving 4" more wheelbase. I also installed shackles that are 1.5" longer than stock. Extended brake lines, a lengthened driveshaft, moving the rear shock upper mounts to the back side of the crossmember, and fender trimming are required. I also installed a MAF U-bolt flip kit. The rear pinion angle was 6* up after everything was installed.
Lengthening my original shaft may have been easier, but the local shop wanted $150 for a re-tube. Instead, I found a front double cardan shaft out of an '85 4-Runner for $75 and decided to use it as my rear driveshaft as it was the correct length to work with my reversed springs (~26" with no splines showing). I made it a hybrid shaft as part of it is '85 4-Runner, and the other end is part of the 40's original shaft. I used the 4-Runner double cardan end on the transfer case. I had to drill out the holes only slightly to allow the larger FJ40 studs on the parking brake drum to fit the shaft flange pattern. On the rear pinion end of the shaft, I used the FJ40 shaft end that was originally attached to the parking brake drum. The bolt pattern and splines matched perfectly and the length is right on.
My only issue was pinion angle. With a double cardan shaft, you want the rear pinion pointed up at the transfer case. I am currently running 6* shims which gets it pretty close. The rear pinion is still pointed a little low, but I have no vibrations or binding of the driveshaft, even at full stuff and full droop. I expect the new springs to settle a little as I break them in. The setup will be fully tested at the Southern Cruiser Crawl on Oct 13-15.
I like the way my 40 handles on the road better now. Keep in mind that I went from 2.5" lift springs with stock shackles and no caster adjusting shims on 33 x 10.5s to 4" lift springs with 1.5" longer shackles and 4* caster shims up front on 35 x 12.50s. Once I get the TREs installed and the front end aligned, I should be even better. I really like the way it performs off-road as well.
It's not that much of a pain to redrill. just grind off the centering pin nut, punch it out, flip the 2nd leaf around, drill, and put a new pin in. Done. NAPA usually has the pins in stock, and I usually use the locknuts that bite into the threads to keep em nice and tight.
I've got '55 rears under both ends of one of the '40 I'm running these days. Love them and I'd never go back to the stock springs. '60 rear springs would be functionally identical.
OK Guys I have been researching and I have a question, I have a Aus 77 Cruiser and was thinking why can't I install another front pack in the rear? 55 springs are a rare find down here and I don't want to many hassles with changing all my pins over and trying to run 60s springs. Won't another front set in the back give me a better ride, better wheel base and be a bolt on change?
So gathering more info from this thread, it looks like 45s springs are longer than 55s, what are teh draw backs of using this longer spring?
I figure I will have to reverse the rear hanger anyway and it looks like the spring would work, are the bushing dimensions the same from relative years?
I would also have to extend the guard, but other than that is there something I have missed?
45 springs are alot longer. (9" I think) You will have to mount them on custom hangers that are gussetted up the bumper. They will reduce your depatrure angle. They ride ssssoooo nice though! I redrilled my perches and run a stock 4 spd front D/S in the back.
Edit: I used a mixed bag of leafs, I think the top 3 are 45 springs, then I used some 40 leafs under those. I would have go look to know for sure (I can later if you want). You also have to worry about spring pin - bushing size difference, but its the same as 55 springs.
sorry i hate to interupt. im using this thread for other information.
the drivetrain im putting in is about 4 inches too long and dont want to cut it out of the rear driveshaft.
would a shackle reversal in the rear be a good way to get that 4"?
also, is that the most i could gain?
i plan on keeping the stock fj40 SOA springs. with lots of torque (maybe 400ish).
would spring wrap be an issue?
i dont get it. the FAQ page is all about the forums questions. "how to post a thread", "what are smilies?" are you serious when you say that i will be amazed?
i have been using the "search" button frequently and it has been great for finding relivant information although sometimes there are a few additional questions that people might have. i am sorry i invaded on this thread with my own questions, i just didnt want to clutter up the pages with new threads on questions that have relitively quick answers. i just need to get information on this as an option fairly quickly. good luck with any questions you might have in the future.
quote: #35
"fj40 SOA springs"
quote: #36
"I believe it's more of a SOA issue"
thanks for your help on the spring flip issue, 3 1/2 inches is about what i need to gain.
