Speedometer Assembly Difference
Texas
Had one of my 43s in the shop while the cylinder head was getting repaired. My gauges haven’t work since brining the truck up from Colombia, so I bought a new cluster (obviously the one on the right). To me they like identical, but the shop that has it is telling me the new one will not work. Anyone seeing something that I don’t?
On the top, not the right. The upload rotated it
Just a guess but look at 8 o’clock. Amp gauge? 50 amp vs 30 amp?.
Apparently the new cluster has a plug for an internally regulated alternator, and my truck uses an externally regulated one (even though it’s a 79). New plug has 3 prongs on the left side of the cluster that my old one doesn’t. Wondering if there’s an adapter that could make it work as I haven’t been able to track down a new older model assembly for relatively cheap
I don’t know, but you might spend some time looking and asking in the instrument cluster thread started by @bj40green .
Lots of info to help you.
early model speedo cables screw onto the instrument cluster - later model cables clip to the cluster
that difference alone prevents crossing over between early and late model parts
That wouldn’t really matter though, as you can always get a new speedometer cable. I’m more so curious about the alternator issue and if there is a wiring fix or a way to circumvent that.
