I found it easiest to grab the wiring behind the instrument cluster.
There are two VSS and from what I can tell from the wiring schematic they do not talk to each other. I drove 400 miles with a bad VSS the same one you interrupt with the calibration box for the speedo and noticed no change in the way it ran or shifted. The only difference when the VSS was disconnected was CC did not work along with the speedo.![]()
I think I was looking at one of your posts, Phil and a couple from Landtank, and even Slee's install instructions for their Marks Adapter. I could not get a clear enough picture in my head to start cutting wires behind the glove box.
I believe that is the advantage of the Yellowbox over Slee's Marks Adapter, other than cost. They provide a plug and play for us laymen. Although, I would have figured it out eventually if I did not have the plug and play option.
I cant speak to the yellowbox being waterproof, but its easy enough to bring inside the vehicle, why keep it outside?
You only cut one wire and the box wired in series. The only other wiring needed is 12V
According to the 96 EWD, page 162 it is probably the Red and Orange wire coming out of the IH1 connector. But at the time I was researching this a couple years ago I did not understand the EWD enough to install this way. Not when there is a plug and play option.
If I had it to do again, I would probably still use the plug and play.
