Speedo Correction
"the whale's vagina", CA
thinking of getting one of these little boxes, seems much more reasonably priced than the slee option:
http://www.yellr.com/yb_home.htm
Has anyone used these and like them? also, I swear I read somewhere that there is a benefit for the vehicle's computer to have the speedo corrrected, is this correct? I am wondering if it uses the signal in any way to adjust engine settings, etc? or is it simply just altering the signal going to the speedo and that is it?
Thanks,
Noah
I have the Yellowbox. My first was defective but since replaced it's worked great. There are dip switches so adjust for different tire sizes. I'm about to switch to 315s so I will have to change dip switches again.
Noah, as I mentioned in that other thread I have one and am very happy with it. The box itself is very small, about 1"x1.5" or so. I got the plug and play harness and installation was about as easy as it gets. I mounted the box to my slider gusset for easy access until I got it dialed in but now I need to figure out where I want to permanently mount it. I can try to get some pics if you want.
Your link is shows version4. Version 5 is much smaller. Here is what it looks like with the plug and play harness. The quarter is for size reference.
Noah, as I mentioned in that other thread I have one and am very happy with it. The box itself is very small, about 1"x1.5" or so. I got the plug and play harness and installation was about as easy as it gets. I mounted the box to my slider gusset for easy access until I got it dialed in but now I need to figure out where I want to permanently mount it. I can try to get some pics if you want. Your link is shows version4. Version 5 is much smaller. Here is what it looks like with the plug and play harness. The quarter is for size reference.
There wasn't a plug and play option when I installed. Would have been nice.
found the answer to my own question, looks like it helps to correct the wrong signals to the ecu and other areas as well, from the instructions:
Other electronic vehicle systems
Other electronic vehicle systems may also use the speed
sensor signal to calculate various perfomance parameters.
Including;
· ECM/ECU (Engine Control Module),
· PCM (Powertrain Module),
· ABS (Antilock Braking System), traction control,
electronic stabilisation, cruise control, etc.
Systems that may underperform if the speed signal is
inaccurate.
I think there was one in classifieds recently
Including;
inaccurate.
So how did the yellow box work out?
Has there been any other better options out there in there last couple years?
I have the new version 5. Works great. I installed it like landtank described. No harness. Just hard wired behind glove box
I still have it, had problems calibrating it and got frustrated. Probably will try later and wire it into behind the dash. I just got frustrated with figuring out the flashes, etc to get it programmed correctly. I am only running 285's right now so not even sure if that much correction is needed.
Could you feel a difference in braking, shifting cruise control?
I have 315s...
I'm just more concerned for the equipment working correctly than the speedo being right.
I have 315s...
I felt no change . Only change was I am not racking up fake mileage.
With 285's on my LX I am going 5MPH faster than the speedo says.
You are actually racking up less if you have larger tires.
I like mine. Did the plug and play harness. There's enough wire to plug into the transfer case and run the Yellowbox up into the cab. There is a large grommet just under the glove box on the trans tunnel, at the edge of the carpet. Lots of zip ties and dialectic grease are your friend.
Easy to calibrate, just do the math. I'm on 285's with 4.88 gears.
This made a difference on my transmission shift points and mostly the torque converter lockup happens when is supposed to.
thx for this, I will be looking for that grommet, so it is near the stock center console?
On the trans tunnel just under where the carpet ends forward of the radio cluster. If you were sitting in the passenger seat, it would be above where your left ankle naturally rests. I do not have my truck handy to take pics, but I will try and get some this evening.
