For Sale Southern Oregon, 1996 Landcruiser, triple locked, 315's, 4.88's, 4" lift
Medford, OR
Website
www.hunttractor.com
Year
1996
  1. 80 Series
Mileage
282488
Color
White
1996 Toyota Land Cruiser FZJ80, 4x4, AWD, Triple Locked (factory), OEM Center diff lock switch , 4”lift, 35’s
282,488 miles and slowly counting, California Rig- NO RUST
Clean title / no accidents, 2nd & 3rd row seating
OBDII- ready for a turbo install
35x12.50/17 ProComp MT2 (all 5 / @ about 65% remaining) mounted on 17" HELO Wheels
Nitro 4.88 Differential gears
Full knuckle rebuilds w/ Nitro birfs @ around 265K miles
Nitro Chromoly Rear Axles
Trail Gear Chromo locking hub nuts
Koyo wheel bearings
Fresh Oil Change- always use Shell Rotella T6 synthetic, Fresh Front Diff. Oil
New front rotors and brake pads
Head Gasket done at 259K miles
New engine harness at the same time
PHH done w/ New heater valve
HPS silicone hoses
All EGR components replaced
New OEM A/C expansion valve
4” lift with Slee heavy springs
Icon Stage 1 shocks
Rear upper adjustable links
Rear adjustable panhard bar
Front adjustable panhard bar
Extended S.S. brake lines
Extended diff. Breathers
Sway bar lowering brackets
OME Steering Damper
Man-A-Free drop brackets for caster correction
Custom front bumper with Warn Zeon 12K lbs winch
Trail Taylor Custom Rear Dual Swing Out Bumper with every option
2” Factory Receiver Hitch
High-Lift Jack
Dual Odyssey batteries with T-Max automatic isolator / monitor
Toyota RH battery box
Edge CTS Insight OBD II monitor (better than scan gauge)
ARB refrigerator plug
Pioneer Bluetooth unit
Pioneer front speakers (under stock grills)
Factory front floor mats
Washer bottle relocation kit
Dynamat Sound deadener
Hella Super horns
Both front Seats gears have been replaced
Wet Okole Neoprene Front seat covers
Custom Defender Roof Rack (8 mounting feet for extra support)
Factory roof rack removed and sealed
ARB Simpson III tent (Used about a dozen times)
ARB Annex for tent (never used) new in box
ARB Awning (mounted but never used)
I bought this Land Cruiser in 2015 and have put around 20K miles on it since then. We have used it for our hiking / snowshoeing adventure vehicle and it has been great. We have taken it to Moab and all over southern Utah, Glacier NP, and all over Oregon and Northern California. We camped in the roof top tent around a dozen or so times too! It has been a great vehicle for us! I hope the next owner enjoys it as much as we have!
I wouldn’t be selling it, but over the last few years we built a Lexus LX450 (same as the 80 series Land Cruiser) from the ground up and it is now our new adventure vehicle. That means it’s time to sell the LC and let someone else enjoy it as much as we have.
The previous owner was a Toyota tech and did most of the work mentioned on the list. I recently serviced it and put new front brakes (rotors and pads) on it along with resealing a leaking birf. This LC needs nothing! It does not burn oil and runs great!
As you can see, the previous owner and I have already fixed or upgraded every known issue that 80's are known for. It has no check engine lights, drives smooth and straight down the road, and stays under 195* with a/c on even when over 100* ambient air temp.
There are a few minor blemishes that didn’t bother me so I never did anything about them: small dent in hood, small dent in front passenger side door, crack in dash, rocker panel damage from PO on driver’s side below rear door, paint rubbed off of a couple fender flares, paint rub on rear hatch behind ladder, missing a little leather on the corner of center console arm pad. It is an off-load rig after all.
This Land Cruiser is ready for your year round adventures! Buy today and camp tomorrow!
Price: $24,500.00 Cash OBO You can't build one like this for this price these days. Don't miss this opportunity to buy this turn key overloading rig.
