source for OEM lockers?
North Jersey
I'm sure I'm not the first to ask this question but I'm in the market for front and rear OEM locking differentials for my non-locked 93 FZJ80 I want to go OEM over an ARB setup for factory design and reliability. The junk yards near me don't have ANY Cruisers at all let alone any 80's Is there a place where I can purchase just the front and rear locking differentials new or used as I'm prepared to modify the front and rear axle housings. Does anyone know what they would cost if purchased new, and PM me if anyone is interested in selling any OEM locker equipment.:cheers:
Thanks
George
Check this link. It isn't cheap. I have done most the work myself and save bucks. I went used on the carriers, however, I am starting to wish I had gone with new. I don't have the expertise to rebuild the carriers and I think the rear is a rough.
https://forum.ih8mud.com/showthread.php?t=114976
Hit boston manglers link for the ECU, switch and dash bulbs. I have a write up someplace on the OEM wiring conversion if you want to go all the way.
https://forum.ih8mud.com/showthread.php?t=113251
I still need to finish the post but it gives you the general idea.
Just get ARBs. It's much simpler for you and have significant advantages over OEM lockers in strength. They are at least as reliable as the electric lockers that came stock on 80's and they don't have the twisted axle spline problem that Christo Slee and others have reported.
If you are buying a truck, it makes sense to get the OEM lockers, since they are basically free. If you already own the truck, the logic shifts the other way. Since you will end up paying roughly the same amount, you may as well use a better locker. JMHO.
I agree with Andrew on this topic. You will pay dearly for the retrofitting of OEM lockers and the benefits do not offset the added costs, IMHO.
If you plan the whole project well, you can come out with a high capacity air source, a larger air tank, with the F&R air lockers and still be hundreds of dollars cheaper than retrofitting OEM.
-B-
B and Andy,
Depends on how patient you are.
Rear locker - $425 (includes shipping)
Switch, bulbs - $34
Used ECU - $100
Harness - $25
Short Side axle - free after putting stronger ones in my truck
Now everything is wired for the front as well and I only need the front harness (Have it $25) and the locker.
The rear is all you need for 90% of the situations we may encounter. So I am in no hurry in getting the front locker for Sarah's truck. When the right deal comes along, everything else is there.
B and Andy,
Switch, bulbs - $34
Used ECU - $100
Harness - $25
Ken,
Where did you find all of the used parts?
George
