Here' s one I wrote on installing the factory wiring.
https://forum.ih8mud.com/showthread.php?t=113251&highlight=oem+locker
Since I am in the mits of this I can give you an idea. I don't have the numbers in front of me but here goes.
Axles and Carriers- if you buy complete units hub to hub expect to pay 800 - 1200 for each. If you just buy the rear carrier which makes the most sense expect to pay 400-600. These are used prices. IIRC a new carrier is around 950.00 plus actuator 400.00 or something.
The two most recent front carries sold on Mud went for 500 and 650. I missed that 500 one by 20 freakin' minutes!!
You can modify the front housing if you want. I think I saw some say they can have it done for around 200. I bought a new one.
If you want to buy a new front housing and carrier plan on 1000.00 for the housing, 950.00 for the carrier and 400.00 for the actuator.
All the factory wiring comes to around 500.00 (if you do the five wire plan on 100.00)
ECU - 250.00
Switch and bulbs 60.00
Knuckle rebuilt, studs, gaskets, bearings F&R etc 400.00
Then as S load of time or money getting all the work done. I have everything done except the axles. All told I think this took maybe 10 hours.
I estimate the rear will take me 16 hours include repacking the wheel bearings. I have no idea how long the front will take. I guess like 24 - 32 hours. I'll do my lift at the same time.
Or, I may break down and have some do the front for me. I have 2 kids under 3 and time is at a premium.
Hope this helps
