Anyone have recommendations on a good soldering iron to do the electrical mods found in our forum?
Im going to do NLXTACY's garage door mod and eventually upgrade speakers and others things in the future.
A station or kit with a corded iron and a case would be good.
Weller is probably the biggest brand and most of their stuff seems good. I actually use my butane soldering iron more than any of the others because that is generally what the job requires. A nice variable temp one is good if you have a work bench or soldering station. But you can use the butane one anywhere. You just need to be careful about which way the exhaust vent is pointing!
I know nothing about soldering irons. I just went to Radio Shack and bought a cheap one that just plugs in to work. I also got a cheapo station to stick it into to prevent burning holes into my plastic work bench/table
Cheap from Radio Shack. I'm a model railroader and I've done my share of soldering, although I won't claim to be high class like an ex who was a TV engineer...
Get the little stand that has the holder and the sponge pad. Get the little can from Radio Shack that is the tip cleaner. Prime the tip when first heated with rosin core solder until it takes. Then plunge the hot tip in the tip cleaner every so often. Works great. Every once in awhile, use the sponge after the cleaner to get the bigger grunge off.
Watch out for hot solder and the hot iron tip and you're good.
NLXTACY, I have everything ready for the mod all I need to do is solder the switch wires to the opener's circuit board. The write up was great. Thanks.
I ended up going to RadioShack and got their:
Five Piece Soldering Tool Set =P/N 64-2802B (30Watt iron)
Soldering Iron Holder/Cleaner =P/N 64-2078
Vacuum Desoldering Tool =P/N 64-2098
and some random roll of solder for under $40.
All these items worked well and I got the garage door mod working easily.
When I'm doing surveillance installs on City buses, I pretty much have to solder 100+ connections a day
The gun is more ergonomic than a pen style iron, it heats up FAST, only works when you're on the trigger, so setting down isn't a problem and it also has a nifty light that comes n handy when you're working under a dash
That being said, if you plan on doing circuit board work on a desk, you'll probably be better off with an adjustable soldering station
I did an internship in college at a laser optics place. The old coot that ran the fabrication lab taught me to soldier. I thought i knew how but damn with the right equipment and a little knowledge he really taught me how to soldier. The biggest mistake people make is temperature control. The weller iron i have has a magnetically controlled tip that maintains the correct temperature for quick and effective soldering.
Quick Tip:
Good iron with correct tip.
Small damp sponge.
When you go to solder wait for the iron to reach temp.
Wipe the tip of the iron on the wet sponge to clean the iron.
Get a small pool of moltent solder on the tip of the iron. The pool creates more surface area in contact with the wire to be soldered and gets to the correct temperature much faster. Helping not to over heat the insulation wire. Once the wire starts drinking up the solder remove the iron and let the wire soak up the solder from the spool.
Been using Weller for the last 30 years. I have a WTCPT station for home use and a variety of tips. Works very well. Throw that RS crap in the garbage.
