For Sale SOLD - Matrix inverter package
Status
Not open for further replies.
Mr Cimarron
DRIVE, BREAK, FIX, REPEAT
Cedar Valley, Texas
I have two inverter packages that were pulled from Toyota Matrix. $75 each shipped. Each package will include inverter, switch, outlet, pigtails and mounting brackets (from Matrix). The little tab that holds the outlet cover is broken, in both packages, and won't hold shut. When I installed this in my 80 I actually removed the cover for better use of plugs.
Are the diff switches identical? Just changed to design of the call outs?
Thanks!
Are you asking if the 110v switch is the same as other Toyota switches? It's the same as a defrost switch.
Sorry Im confused on the 2 switches, are the both required for one inverter? Appreciate the insight!
CS
The 110v switch turns on the inverter and the outlet is where you plug something in. Only one switch needed for an inverter. You will also need to run everything through a relay which isn't hard.
Status
