soa?
Ok so before I begin FYI I have already read the tec section's link on doing a sor and I have searched the subject many times...
What I am looking for here is some pictures of the steering set up on cruisers who did and didn't cut and turn their axles and of the drive shaft angles on each, actually as many pics of the set up in as many varieties of the setup would be great and very appreciated
I am planning on slowly gathing the parts needed to do a soa including putting together two new axles and then performing the swap...
Thanks
-Brandon-
Mac, that sounds like what I'm planning too. do you have power steering? looking to cruiseroutfitters for the axel housing, local guy for the drivelines, not sure on the rest. I would like to do ps and a shackle reversal also but not sure if I could just do a SOA now and work on the rest later.
From what I seen I wouldn't think doing a SR now could cause you any problems later but I'm no expert...
Hi All:
I'd suggest you consider the "high-steer" conversion as part of the total SOA project.
Good luck with the project!
Alan
Seattle
All pro sells a hy-steer kit for $499, seems a little steep, got to be a better way
with soa without cut and turn yet.
My Vote for new logo :ban:
SOA, custom low shackle reversal, cut/turned knuckles, 4x4 Labs Histeer, 14.3" Bilsteins, MetalTech hoops
Done correctly, a SOA will get a TON of axle travel in the front, and tackling ALL of the options for doing it correctly will save you many future problems.
Just done it
I would do everything at once, the SR and SOA. Cut and turn and tilt your pumkin up 12 degrees to get your drive shaft straight up and out of the way, rotate your knuckles back 5 degrees to increase your castor angle. You will need a double cardan shaft to do this right.
the double cardan (CV) is required if you plan to ever run at any speeds with the t-case in 4wd and/or with the hubs locked in.
it's optional if you wisely unlock the front hubs and hit 2wd for ANY road use. I never ran the CV on my front and never had an issue, but even short runs down the road meant unlocking the hubs to prevent vibration.
you WILL need a l-o-n-g travel front shaft with the shackle reversal tho....
Woooow, that one of the best shots of your rig in action I have seen yet IMO.
Your rear suspension really flexs out like mad, nice pic.
not trying to steal the thread or anything but has anyone tried the goldseal superflex ujoints from www.4xshaft.com/Super-Flex.html
I thought these might be good for my front driveshaft because I didnt turn the pinion and the stock u joints (3spd) bind at rest! :doh:
I was also gonna try grinding the yoke till the u joints work at my angle
any ideas
We just finished our SOA yesterday and here are a few things i wish i would have known. We opted not to do a shackle reversal, but did do power steering, hysteer, mini truck disks up front, chevy in the rear, and rebuilt the knucles. It is not very expensive to do it right if you think things through and shop parts out. The cut and turn and the hysteer were by far the costliest aspects, but thats because it was purchased rather than made by us and no shopping.
Cut and turn-400
(with new shock mounts and long rubicon express perches, cost of front and rear)
Hysteer- 450
Mini truck FE- 100
New calipers and rotors front and rear- 175
New brake lines and banjo fittings(pnp)- 35
Rear DB plates- 45
Knuckle rebuild kit- 80
Wheel Bearings front and rear- 50
Power steering bracket- 45
power steering pump and hoses- 200
Power steering drivelines and parts- 125
Drivelines- 150
This does not include things like oil, permatex, grease, paint for axles, etc. A bit under 2K but its big and cool. It took a long day after the housings came back to put everything together, but we had all the parts there minus the drivelines and the drag link which gets custom cut by marlin when you give them the measured length. Drivelines took 2 days and dont see any way around those sort of delays. Spent about 2 weeks on here reading to get all the bearing numbers, brake years and makes, reading to pick marlin over all pro, and whether to cut and turn or not, whether to SR or not, and what brakes and PS i wanted.
I would greatly suggest trying to get all the parts together. As you mentioned, you have read the tech stuff, and my interprutation is its not a good idea to NOT cut and turn on a short wheel base vehicle. Either the pinion is pointing too flat, or the castor is pointing the tires into the ground. One last thing, we had the tires allready and marlins stuff looks very nice and worth it. Good Luck, Eric
Sweet thanks for the pics so far not to sound picky but I'd like to see some not so close up so I can get a better idea of the angles produced in relation to everything else and why they are bad this goes for steering and driveline I'm a visual learner so as many pics as possible in as many variations as possible...woody that rig is awesome it's basically what I want mine capable of with still being able to drive it on the road as a DD
SO BIG THANKS TO ALL OF THOSE WHO HAVE PROVIDED PICS ALREADY!!!
KEEP THEM COMMING!
Thanks
Brandon
With a SOA I think the SR is one of the cheaper things to do, I would do it while you are doing the SOA, SR is more or less just cut and welding with a few brackets, I know thats abit over simplified but its not too difficult, Like said above done correctly it will work great and cut down on alot of problems.
Good luck
We did not do a SR when doing the SOA. Definately did the hysteer Marlin arms and GM PS. Cut and turn was competed without issues. There is also this traction bar..... do you plan to run one? The bar (not in the top picture) runs to a small shackle....
This is the shackle set-up...
I am happy to pimp Fyman's sheet: he did awesome work on my 55's SOA.
yeah i probably will run something like that...do you have ant good pics of the hi-steering set-up where I can see the new angles power steering too nice work by the way! looks good
Question why is a SR so important?
Here are some photos of the steering..... I am not sure why a SR is important, I haven't noticed any repercussion from not doing it. There is a theory on cruiser steering which caused some manufacturers to make a "steering correction kit", I think this was basically a SR but maybe people do it because the shackles hang down so far for approach angle? I am sure someone will chime in more qualified than me....do these photos help? I could take more...
there are more pics and stuff here on my project..... http://www.birfield.com/modules/gallery/Making-of-a-Real-Pig?page=1
