Most people that want SOA want bigger tires. If you want bigger tires, you want Power Steering.
Having said that, I would do it all at once. SOA, PS, and a Shackle Reversal. It's an expensive process. I know of a rig that did the SOA but no PS. They now have to spend a couple of thousand to do that. Doesn't make sense to do the job half way.
Not sure where you live, but check with any shop, if you are going to pay labor to do the job correctly, a saginaw PS conversion is expensive.
Now, doing it at home is obviously different. How much would you charge for the following:
Brackets for frame for box mount
Bracket for PS pump
Labor for welding brackets to frame
Labor for cutting/reinforcing cross member
Labor to install PS box
Labor to install PS pump
New PS box
New PS pump
New hoses
Asembly time.
is it beneficial to run GM axels with the SOA? i can get them and installed for $500 total and was wondering if it was worth it.
Ps is a most. Just turning the 31s offroad is hard
check around on this site you can get everything reasonable to do the job right none of my 6 legal 40s have power steering 3 stock and 3 with soa and 35s or 38 hawgs and one with military axles off road with lockers some times it steers a little hard but after 35 years of driving 40s maybey im used to it good luck
does anyone want to come over and help me out with my SOA and Saginaw power steering lol i got all the stuff for the ps in my shop but i havent got the confidence to do the soa yet!and i run 33s on my 40 and a 10in steering wheel and let me tell you i usually have 2 purple thumbs and alot of blisters on my hands from the steering wheel going whatever way it feels like on the trails
