can't speak for lil john and tucker, but i'm setting mine up with stock sway bar and i cut the links out of the ends and welded in a thicker rod from the metal place down the road
Only off the mother of all SOAs (TWRECKS) done by the masterSuperT said:Do you have pics of an extended swaybar plus traction bar set up?
Question, Does anybody know of a reason why I couldn't adapt a 55 sway bar to my 60 axle. I'm having a heck of a time trying to fit the 60 sway bar around my big tank and the new 4+ ubolt flip kit. The shocks are going to get in the way, now.
Thanks, Ron
Thanks, Ron
don't know if it would be good for the springs to be on the limited patch of axle. pick up your future perches and just set them on top of the axle with the springs on top. my front end is still sitting like that on the pickle. rear sat like that for yearsAnyone have any info or links I missed?
At the moment, I just want to flip the springs over the axles and slap some cheap/bald 37/39's up on my rig to get a better idea of where I'm headed with the build (won't be a driver for some time yet).
Since I'm only doing this for mach up purposes, can I just flip them as is? I plan on going to bigger axles when I make it a runner. Just want to see how everything will flow, so no changing mounts, leaf springs, outboarding, and all that jazz for a while.
Thanks in advance.
Cool. I was wondering about his setup.
Thanks once again Ige. For all this help, I'm going to have to drop off a coupe six packs to piglandia next time I'm up that way.
